Old 11-18-2017, 06:11 PM   #1
MailManX2
MailManX2's Avatar
Tired of looking at it... for now..
Got burned out working on my 60 Apache so it's been sitting in the garage on a rotisserie for quite a while (years). Last week I bolted the front suspension on (Jimmy Meyer) and mocked up the rear suspension, which isn't right but allowed me to move the truck out of the garage. I'll rework it later..
Using my Kubota L3901 I hauled the truck out and put it in a shipping container for storage. I need to make something for the tractor that will allow me to move the truck back up to the house without a struggle. Something that I can lift the front end and will allow the truck to pivot behind the tractor. That way I can easily move it back to the garage so I can work on it if the mood hits me.
Oh, now my garage is half full of woodworking tools that were in storage in another shipping container...
Ken B
60 Chevy Apache
2019 Chevy Silverado Z71
Why buy something when you can build it for twice the price..
Just because something can be done doesn't mean it should be done...
MailManX2 is offline   Reply With Quote
Old 11-18-2017, 08:46 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Tired of looking at it... for now..
At least you have a dry place to put her!!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-19-2017, 02:32 AM   #3
'63GENIII
'63GENIII's Avatar
Looks like you need a hoe on that 3901. Got one on my BX25 and it works great as an engine hoist. Well, actually an engine hoist works better but the BX is more fun to use!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 11-19-2017, 07:22 AM   #4
Killer Bee
Killer Bee's Avatar
buy or fab a fork attachment adapter and mount a locking pintle claw on it..
fab a crossmember with a lunette eye to bolt or clamp to the frame horns of the tow vehicle..
just about everything else will result in some level of damage to the vehicle, machine, or both..
pintle hookup is keen for high angle mobility and control..
been using these for years in various forms and locations including my present yard at work..
good luck!
Old 11-19-2017, 08:51 AM   #5
wahl4m
i have forks on my jd 4500-slide the 2 forks together -take a piece of box or rect. or channel tubing &slide over the 2 forks {remember 2 forks are stronger than 1 } take a pivot cup -off the top of a floor jack & weld a piece of tubing to hold it on the tubing on the forks -this will give you a swivel -that you can lift the truck up by the rear axle & move it ! if worried about losing it put a small chain from truck r/end housing to the tractor -forks mask ? also i try to wedge this pivot mount on the forks -hope my description is not confusing ! good luck-truck looks good -keep on it -finish it!
wahl4m is offline   Reply With Quote
Old 11-19-2017, 12:25 PM   #6
MailManX2
MailManX2's Avatar
Got one, just didn't have it on at the moment as I was using the tractor for hauling wood...
Ken B
60 Chevy Apache
