Ok guys im gauging interest here....
I have a 68 12 bolt rear. Has about 50 miles on the new build. Im fixing to buy a narrowed 9" to take its place and wanted to so if anyone was looking for a good set up.this is the brake down. It has moser non tapered axles 30 spline with 5 on 4 3/4 car bolt pattern. 1/2 screw in studs. (There is room on flange to drill 5 on 5 if a person wanted the stock pattern) Richmond 4:10 gears (3 series carrier) Strange mini spool 11x2 gm car drums ( truck drums will fit if you redrill axles) Everything is new . Even the brake lines. The onlything it will need is the tee for the brake lines. I run a custom hose w/tee. It will also need e brake cable's...again i have a custom ebrake set up. Has a chrome diff cover. I will be askin $1100 plus shipping or you could pick it up. I have much more than that in it. Its in my show truck thats pictured.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
Re: 68 (short rear ) hopped up fresh. Possibly for sale
Bump
| Bookmarks |
