What size tires are you guys running on 20's
Hey guys just picked up some twenties and just trying to get an idea of what size tires to run on it not sure if going to lower the truck or if it is a tad Lower then stock now
If you can post some pics and sizes I appreciate it |
Re: What size tires are you guys running on 20's
No idea what your rim width is so can't comment what would work for you.
Mine are 20x10 275-40 and 20x8.5 245-45 ![]() |
20 x 8.5
I have 18 so i cant help you.
I'm running 255/45R20 on a 20x8.5 on the back of mine. Could go larger in both directions, though with a 3 inch drop I don't think I'd want much taller. The lip of the wheel tucks in the fender. The 255 is fairly safe in that there is room on both sides of the tire in the wheel well, could probably go 275 maybe even a little more. May go bigger eventually
#7 | |
tire sizes:
275/40/zr20 rear 245/45/zr20 front
1964 C-10 short bed 406 small block 700R4, 4:11 gears 20" wheels |
