![]() Join Date: Feb 2009
Parts ID & Process for removing rear leaf springs on 71 C-10?
This is not a rolling chassis. Only parts on the frame are the front and rear suspension, engine and TH400. I've pulled everything else, but I'm apprehensive about the suspension. Probably getting some help anyways, but the guy has never worked with leaf springs.
1. Can anyone advise the process for removing the rear leaf springs? The image below may help with description. 2. Also, if anyone can ID some of the parts in the image it's appreciated. On a side, I plan to put the frame on the stands, and lift the pumpkin with the floor jack. I figure it's a good idea to strap the axle to the frame. Better than dropping the axle............I'll secure the pinion side of the differential as well............... I'd use jack stands with the axle, but the stands won't secure the frame and axle. Not without shims anyway. Thank you.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 11-25-2017 at 05:42 PM. |
Re: Parts ID & Process for removing rear leaf springs on 71 C-10?
I would put a 4x4 above the axle on the frame and use rachet staps to lift it up.
3. is a spring locating plate 4. is a leaf spring shackle Question. Is this the original frame? I have never seen a factory leaf spring Chevrolet in the 1968-1972 years. doesn't mean they didn't make them, just havent seen one. |
#3 | |
Is the pin or bolt called a spring locator as well? Both 1 & 4 are shackles? I suppose 1 is a "shackle assembly" and 4 just a shackle? Yeah, it's the original frame, the leaf springs are to the SPID & build sheet. It's a SWB too, go figure. I know a knowledgeable guy who says every Custom Deluxe he's seen had rear leaf springs, but I think it was ordered this way by the original owner. He used this SWB for all things recreational. You'd have thought he was buying a C-20.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
1. You can disguish between the two by Rear Leaf Spring Shackle (1), and Leaf Spring Pack Shackle (4)
Locating "bolt" "pin" "locating pin" are all the same in this application |
#5 | |
Any ideas what order to pull the leafs still open. One thing I've heard is to clamp the springs together before you hit the nuts and bolts. I don't expect to need a torch, and the joints are well soaked. I think I've used heat on a few bolts & brake fittings, and even then just a heat gun.
I would lift axle, then do u-bolts, front spring hanger, rear spring hanger.
#7 | |
Appreciate that, thanks a bunch. I updated the image per my edgeucation ![]()
Nice!
Had some family over for super, and my wife's nephew is a seasoned body/paint dude. He's a great guy. Anyway, we were talking about my truck, drinking some beers, and we jumped into the rear leafs..........Literally. He says" let's do it".
Followed your advice 1950 Chevy Wagon (nice), including the 4x4, and things wen't smooth and quickly, thank you. Smooth until we got to the bottom shackle bolts, wholly smokes. He's strong as an ox and busted a breaker bar (Craftsman). That was a close one. Anyway, he figured we could bust the bolt loose leaving the nut on, because it wasn't budging. I see his point, but these don't work that way, nut has to come first. We pulled the nuts and.............THOSE BOLTS AINT COMIN OUT!....After half an hour or so we declared it a night, twice. Even after "pipes" hit one good and hard with a sledge hammer. For "one last shot" I hit them with more penetrating oil, trying to get inside the bushing. Grabbed a 3/8 ratchet extension and respectable hammer and gave the "easy side" some good punches, ah, that's the ticket. Grabbed the punch to save the extension......Nope, I'll take the extension (ha!). Not long after the easy one was out. RH wasn't as friendly, but it worked. The "boys" were helping. It was a nice evening. Not much left on the frame, and I'm happy to say I've yet to cut anything or use a torch. Just penetrating oil and a heat gun where needed. Front suspension will be the only exception, only because of the top ball joints. Anyway, thanks again Warren, appreciate it. It's nice to know how.
Glad it worked well for you.
