How can I remove the oil cooler
I want to delete the factory oil cooler on this 87 I'm working on. I'v seen the bolt in oil bypass part that people say you need, and maybe I am dense, but I don't see how installing that piece allows the oil filter outer O-ring to seal against the block.
My mother is a recent cancer survivor and this truck build is for her |
Re: How can I remove the oil cooler
if your set up is like my 1990 nbs style, you basically remove all that crap and throw it in the garbage then you have to buy a adapter that screws onto the block
https://www.summitracing.com/parts/a...iABEgJXzfD_BwE ![]() if you order that adapter it does not come with a gasket. which i found strange but i guess if a bit of oil leaks its not going anywhere when i did my 93 s10 it was just a double sided threaded piece |
What threads are the radiator fitting for the cooler inlet/outlet? I need to buy plugs for those if I remove the cooler lines
| Bookmarks |
