Old 11-20-2017, 01:35 PM   #1
Racmad2019
Spare Tire Mount for 1973 GMC 2500 3/4 ton
I'm working on my 73 3/4 ton. Need to know where the spare tire goes---Driver side bed or under carraige behind differential When I bought it; the spare tire was loose in the bed. I want to install it where it was originally placed.Name:  Envy.JPG
Racmad2019 is offline   Reply With Quote
Old 11-20-2017, 01:52 PM   #2
DBLSPRT68
DBLSPRT68's Avatar
Re: Spare Tire Mount for 1973 GMC 2500 3/4 ton
It's a matter of choice. The factory mostly put them under the bed, behind the axel. You could get a bed mounted bracket (dealer installed??) for the bed. There would be holes in the bed and upper rail, for one of those. I like the under bed mount better.
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 11-20-2017, 02:16 PM   #3
tucsonjwt
The spare belongs under the bed in front of the rear axle. You can get most of the parts from LMC, or you might get lucky and find the apparatus in a junkyard. Most people remove the spare in order to accommodate a receiver hitch. If you move the left side support bolt forward about an inch or so you can still get the spare in that location but it will be tight. If you use an aftermarket monster tire for a spare it will not work.
tucsonjwt is offline   Reply With Quote
Old 11-20-2017, 03:45 PM   #4
Keith Seymore
Keith Seymore's Avatar
Bed mounted spare was optional, RPO P13.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-20-2017, 04:28 PM   #5
cadillac_al
The bed mount looked more macho with a gnarly 750-16 tire. I always figured it might even help in a rollover to give a little extra support to the drivers side cab. I wish I had a good pic of mine. My bed is full of junk at the moment.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
