11-20-2017, 09:25 PM | #1 |
4l60e trans adapter to a np 205 transfer case
what adapter did you use for this application?
11-20-2017, 10:44 PM | #2 |
Re: 4l60e trans adapter to a np 205 transfer case
advanced adapters
11-21-2017, 01:11 PM | #3 |
If you can handle a little machining, many people have installed a VSS on the back of the np205 and just used the AA shorter output shaft meant for the TH700-NP205 combination.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
11-22-2017, 04:11 PM | #4 |
True, the output shaft will work, but he will still need to adapt the 4L60E case to the NP205. Not sure where you would install the the 40 tooth VSS gear on the outside of the case. The best and easiest way is to use the AA adapter.
