![]() Join Date: Nov 2014
402 water pump questions/advice??
Rebuilt our 402 bb. Now for water pump??? Ordered a flow kooler water pump bra- 1673. It is the wrong one it won't bolt. It has a short water pump. We have the old one. It looks same but bolt hole are definitely wrong. Called Summit. They are returning it ok. But they asked me the dumb questions of which way does the motor turn clockwise or counter clockwise.?? Guess I don't know and the engine is still on the engine stand and not yet installed . Summit says the one we got turns clockwise and it won't fit. They Gave me another number of a pump that turns counter clockwise of EMP11105. which is a Stewart pump and it turns the other way and they say it will fit. Now am really confused. Help!!! Only thing I seem to find on here is standard rotation. It is a completely stock truck. Anybody got any part numbers for the correct water pump.? It's a short pump.
And when you look it up to cross it it does have 2 different models of 6.6 402. One with a T and one with a U. Is that a Vin or engine block code? I think am over thinking this stuff. Thanks in advance for any answers. Didn't think I was this confused but guess I am. Last edited by painterljp; 11-21-2017 at 01:09 AM. Reason: Spelling. |
Re: 402 water pump questions/advice??
not sure what they mean by rotation on the engine. it only turns one way. but the later BBC 454 with serpentine belt system has a water pump that rotates the opposite direction. and it also fits the older engines. I have one on mine that I picked up at the parts store.
Engine runs clockwise. The serpentine belt system there rotates the pump counter clockwise ( reverse rotation ). I guess it depends on which way your belt system ends up rotating the pump. Standard rotation is clockwise and reverse would be counter clockwise.
My 402 has the same serpentine setup as Doug's68SS there and so uses a long, reverse rotation pump. I think they can be had at the local parts house for less than 50 bucks. ...Or you can opt for some very polished up ones from Edel and others for big bucks! Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
This is just stock no serpentine belts v belt system with factory brackets. Guess will just send it back to summit but auto zone and such all have to order it. Will try napa. Don't really want a rebuilt pump just as soon have a new one. My past with regards built pumps from auto zone and O'Reilly haven't lasted long and a bb is harder to keep cool. Was going to go with a new pump. But where to get one.
What was wrong with this? What bolt holes?
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
Yeah clockwise/counterclockwise are the least of your issues.
![]() Join Date: Jun 2005
I used NAPA p/n 44088 on the '71 402 in my truck. That is a new Tru-Flow unit that was around $100. You can get a reman unit for less.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
I don't but anything reman, EVER!!!
The Chevy engines starting in 1987 used serpentine belts, yes this was first year for fuel injection. The back (smooth) side of the belt turned the water pump, which meant that the fins in the pump have to be aligned opposite of oldie pumps. The Stewart pump not aligning with bolt holes sounds screwy, something very wrong there. I'm no expert, but I sold auto parts for 13 years, AND never assume anything. Call Summit or Jegs tell them you have a STOCK Chevrolet pickup and you would like an aluminum pump. I say this loosely, but most of the short BB water pumps should work, Corvette stuff can be different, beware... Hop this helps... |
Called Napa today they have a new Gates pump for 100. Not rebuilt a new one. On Friday gonna take the old pump down to match it up. That should work. Just heard a lot of good things about the flow kooler pumps cooling better but they won't bolt up not going to cool better. So you all don't order one they won't work. They said to send in my old one and they will put new guts in it for around 250.00!!! Not gonna do that. I think 100. Is steep for a pump but will gladly get it cause it's a new pump not rebuilt. Thanks for part number it is correct number. Thank you. Thanks for all the answers to my dumb questions.
#11 | |
