11-21-2017, 02:58 PM | #1 |
Tilt Lever Broke
The tilt lever on my 72 broke somewhere within the column. Is this easy to get to or is major job? Does anyone even have parts like this?
11-21-2017, 03:05 PM | #2 |
Re: Tilt Lever Broke
I would contact board member kevsclassic he refurbishes tilts and sells them here I bought one years ago and it was spot one
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
11-21-2017, 11:37 PM | #3 |
(EDIT: Yes, my second memory below was correct. If you can get to the broken stub, you can unthread the entire thing and replace with no disassembly. If you can't access it, you'll need to tear down the column to where you can.)
It's been a little while since I had my column in pieces, but it's not particularly difficult and if I remember correctly the tilt lever is pretty easy to remove/replace. If you've never disassembled your column's top end before it might be an hour or two job. On second thought, I'm remembering that the tilt lever might just thread in, no disassembly required... maybe try to unthread the portion that's left, if you can get hold of it with a tool. Sorry for the uncertainty!
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED Last edited by joeydurango; 11-21-2017 at 11:50 PM. |
