Old 11-21-2017, 07:03 PM   #1
LukeC10
Door Striker Adjustment Maxed Out?
I just installed new weather stripping on inner door areas and now the back side by door handle of both doors stick out over 1/2-3/4" from the cab. I loosened the door lock Strikers and adjusted them towards the inside of the cab, but they both barely moved before being maxed out. If I put pressure and push the doors in they line up perfect, so all I need is the striker moved another 1/2-3/4 towards the cab interior.
All I can think is to drill out the striker hole more to give more adjustment, has anyone ever done this?
LukeC10 is offline   Reply With Quote
Old 11-21-2017, 07:16 PM   #2
Jaysonb
Jaysonb's Avatar
Re: Door Striker Adjustment Maxed Out?
I am going to guess that after you installed the new seals that you are only catching the first click on the door latch. Try moving the striker ro the outside untill you catch both clicks, then adjust.
Jaysonb is offline   Reply With Quote
Old 11-21-2017, 07:24 PM   #3
LukeC10
You called it. Wasn't aware there were two click in the latch - just went outside and adjusted the strikers the opposite direction and it worked great, latches double clicked and doors lined right up. thanks man.
Old 11-21-2017, 07:43 PM   #4
Jaysonb
Jaysonb's Avatar
Glad I could help!
Old 11-22-2017, 09:01 AM   #5
sweetk30
sweetk30's Avatar
same as a hood .
safety AND full latched . . . . they dont want you falling out on the road or the hood flying up .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 11-22-2017, 06:03 PM   #6
LukeC10
Originally Posted by sweetk30 View Post
same as a hood .
Yeah it makes perfect sense now for sure, good to know there are two clicks, just wasn't aware and those strikers were driving me mad.
Old 11-22-2017, 10:34 PM   #7
sweetk30
sweetk30's Avatar
also the plastic wears out and falls off .
makes them sloppy and rattle .
some have had good luck with PEX tube cut to length and slid on for a cheep / effective fix .
Old 11-22-2017, 10:37 PM   #8
GMDad
GMDad's Avatar
I had trouble closing the drivers door on my 86. Next thing to slamming it to get it to close. Bought a new striker bolt with the plastic sleeve on it and now works perfect.....
GMDad is offline   Reply With Quote
Old 11-23-2017, 01:06 AM   #9
Desert_Eagle02
1/2" PEX tubing works great for a replacement sleeve on the striker.
1978 GMC K25
1984 Chevy Scottsdale K10 built 350 4"lift - SOLD
Desert_Eagle02 is offline   Reply With Quote
Old 11-23-2017, 09:58 AM   #10
GMDad
GMDad's Avatar
Do you take the washer off or slide it over the torx head part? I would think it would be kinda sloppy on the stud doing it that way. Only $10. for a new one so wasnt real bad but the pex is cheaper for sure.
Old 11-23-2017, 02:34 PM   #11
Desert_Eagle02
Take the washer off and put it on that way. It can be a little hard to get over the threads. Or the quick fix way is to cut your size, then cut a slit along the side and put it on the striker that way. I've never had a problem doing it that way.
1978 GMC K25
