Old 11-21-2017, 08:24 PM   #1
Trakter
Clutch Fork Grinding
Hey guys,
I've lurked around here for he last few years and have always been able to find a thread regarding the problem I had... until recently. So I figured I'd join up and ask away.
I have a 1977 K10 that was originally a 350/SM465/205. I have since swapped a 6.2 diesel from an 83 K5, as well as converted to hydro clutch. I have used a factory hydro bell housing, factory pedals and oem replacement slave and master cylinders. I used a flywheel, clutch fork and clutch set from Oreilly's for a 1985 k10 6.2 diesel. Master cylinder placement was eyeballed from pictures as I had nothing in person get measurements on.
The issue I am having is that the clutch fork is grinding on the pressure plate. When I apply pressure to the clutch pedal the grinding stops. I think it may be as little as 1/4 inch of movement that silences the noise, it doesn't take much.
I am trying to figure out what is out of whack. I remember having some issues with the pilot bushing at first, and I did not do any sort of bench bleeding to the slave or master cylinders. Could it be the master cylinder placement?
Open to all thoughts and ideas.
thanks,
John
Trakter is offline   Reply With Quote
Old 11-21-2017, 08:35 PM   #2
4x4k30
4x4k30's Avatar
Re: Clutch Fork Grinding
did you use a new ball stud and new clutch fork ? if not that's probably your problem they wear and get sloopy and noisy
4x4k30 if trouble was money i would have plenty
4x4k30 is offline   Reply With Quote
Old 11-21-2017, 08:42 PM   #3
Trakter
New clutch fork yes. New ball stud no. I can definitely try that.
Old 11-22-2017, 08:57 AM   #4
sweetk30
sweetk30's Avatar
had the same problem years ago .
1984-older is 1 clutch fork for mech linkage . pic = old rusty one.
1985-up is hydraulic fork for hydro style . pic = new shinny one .
there both bent in different ways and also depending on the style of clutch can rub the fork . if using 1985-up hydro fork you cant use 3 finger clutch cause it rubs the fork with the deeper pressure plate design . i had to use a oem style multi finger pressure plate and problem solved .
here is a few pics of the difference i found after pulling my trans/tcase for a second time.
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 11-23-2017, 02:26 AM   #5
Trakter
Very interesting, my fork is grinding in the exact location as in your picture and I'm using the "3 finger" style clutch. I'll swap in a diaphragm style clutch and see if that does the trick. Thanks!
Old 11-23-2017, 09:44 AM   #6
sweetk30
sweetk30's Avatar
yep 3 finder is taller than diaphragm = hits the fork .
