Porterbuilt 1" Narrow Arms
I have a set of V6 Drop Member Air Bag arms for sale that can be used on a factory cross member or a V6 Drop Member. (you will need lower shaft from Porterbuilt) They are new never used. I purchased the V6 drop member and have decided to upgrade to the V7 for engine packaging reasons. The arms were installed during mock up of the front suspension and then removed.
Current value on PB arms is $1100 I am looking to get $950 OBO from the arms. From the Original Invoice. Part Number #CA6370-1N-C10-DM6 1" NARROWED CONTROL ARM SET 63-70 C10 DROPMEMBER VERSION 6 UCA-1N-C10 LCA-1N-C10 BJ6370-C10 CA-DM-V6 Last edited by Longhornss; 11-29-2017 at 04:08 PM. |
ttt
Re: Porterbuilt 1" Narrow Arms
bump
Diggin The SquareLife
Pics
67-72 parts collector,…
![]() Join Date: Nov 2002
X 2 on posting pics.
Are you saying the uppers AND lowers both have cross shafts so they will work with a stock crossmember? Or just the uppers?
Sorry lolife99 the lower arms do not have the shafts but can be ordered form PB.
The other thing I should mention is that the sway bar mount is only tack welded to the lower control arms because when I ordered the arms I was not sure which sway bar I was going to be using, The Porterbuilt bar was not available at the time. This tab is easy enough to have welded solid. Clearly the Coil over shock does not go with the control arms that was only attached for shock mock up purposes. Thanks For the interest |
Do you know if these move the wheel centerline forward?
If they do, I will take them, if they get to me.
I cannot say for sure, I know they were designed to work with the extreane drop member and center the wheels.
What is your plan for the arms? Factory crossmember or on a PB drop? |
So it looks Like the original Invoice I have is for 1" narrow arms not narrow and forward.
Part Number #CA6370-1N-C10-DM6 1" NARROWED CONTROL ARM SET 63-70 C10 DROPMEMBER VERSION 6 UCA-1N-C10 LCA-1N-C10 BJ6370-C10 CA-DM-V6 |
These are still available.
Posted via Mobile Device |
#13 |
bump
#14 |
These are still available, I am open to offers.
#15 |
New Year New Bump.
#16 |
Still got em?
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together |
#17 |
#18 |
These arms are still available if anyone is interested PM me an offer
#19 |
Wondering if the control arms are still available. If they are could you send me a way of contacting you. I am also in Windsor
#20 |
