11-24-2017, 12:55 AM | #1 |
275/60/15 fronts?
Want to get same size for 4 corners to rotate them...but wondered if this size works with 2" drop spindles and 2" lowering springs.
11-24-2017, 09:43 AM | #2 |
Re: 275/60/15 fronts?
What year truck? I had them on my 66 with 15X8 with 4" back spacing and when I did my drop with 2 1/2" spindles ans 2" springs they hit the fenders. I went to 235's on the same wheels and they worked.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
11-24-2017, 01:37 PM | #3 |
Some have done it with the right backspacing on the wheels, but overall, they're just a bit too big.
11-24-2017, 02:15 PM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
I did the same as PGsigns, only I went with a 7” rim.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-24-2017, 02:18 PM | #5 |
Cruzzzn' Vet
With a 2" inch drop they'll work on the front ,but any hard cornering or big bumps you'll wish you ran a 255, 245/60 tire, so in the long run a 275/60 is big for the front.
11-24-2017, 02:24 PM | #6 |
My truck is a 69 2wd 6 lug with I believe the 15x8 steel wheel.
So with my total 4" drop...will 255/60 even work?... |
11-27-2017, 04:09 PM | #7 |
Anybody have a picture of a 255/60/15 with 4" drop in front? Or a 245/60/15 with 4" drop?
11-28-2017, 10:15 AM | #8 |
11-28-2017, 11:40 AM | #9 |
11-29-2017, 04:01 PM | #10 |
Not with these wheels. The backspacing on the wheels above are 3.75" The stock 5-lug rallies are 4.25" bs, which are usually the ones needing clearance, but not always. I'm not sure why some do and some don't. If you keep it 6 lug and run the 6 lug rallies, they have 4" bs, which also clear.
11-29-2017, 04:47 PM | #11 | |
