11-25-2017, 02:57 AM | #1 |
Will 700r4 need a high hump?
My cab is at the body shop and before its painted I wanted to find out if I need a high hump tunnel for a 700r4 trans. Truck is a 69 with a 400 SBC. I have researched this topic and have seen both yes and no answers. Brother's sells a nice steel replacement unit.
11-25-2017, 03:08 AM | #2 |
Re: Will 700r4 need a high hump?
No it will not need a high hump.
In fact a big block and TH400 will fit a low hump with decent clearance. I've had multiple trucks with the 700 and low hump. |
11-25-2017, 07:04 AM | #3 |
Old member
x2.
I had my 305TPI with 700-R4 no problems. I now have 6.0 with 4L80E no problems.
11-25-2017, 07:36 AM | #4 |
I am glad to know this as I am preparing to install a 700 r4 in my truck and was wondering if I needed to change the hump.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
11-25-2017, 08:20 AM | #5 |
Agree that a high hump is not necessary but on my 67 --- bbc even moved forward an inch -- I did have to slightly massage the passender side just below the cover for the 2-4 servo cover. May not be necessary on yours and is no biggie.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
11-25-2017, 12:30 PM | #6 |
Thank you guys. Exactly the information I was looking for. Love this forum!
11-25-2017, 04:31 PM | #7 |
I've got a 69 with a big block--T400 trans and a low hump, fits fine. I can get my hand around it
