11-25-2017, 05:21 AM | #1 |
Converting 70 Blazer to front disc
Need 71 or 72 hub assembly. I have hubs that I was told were from a 72, so I ordered rotors and calipers. The rotors I have don't mate with the hubs, which are too big for the rotors. I'm looking for hub assembly, or a place to buy a 70 conversion kit with drilled, slotted rotors, and wilwood calipers.
11-27-2017, 02:56 PM | #2 |
Re: Converting 70 Blazer to front disc
I've been searching for the same thing. Seems the easiest way is to just find a 71/72 k5/10 axle and swap it in.
1969 K5 Blazer - 507 Light Blue - http://67-72chevytrucks.com/vboard/s...d.php?t=802858 |
11-27-2017, 08:04 PM | #3 |
I have some spindles and hubs from a 72 blazer I will sell.
11-28-2017, 09:09 PM | #4 |
If Timm doesnt want them i would be interested.
11-28-2017, 10:30 PM | #5 |
I will get some pictures Thursday and go from there.
11-30-2017, 02:41 AM | #6 |
11-30-2017, 10:46 AM | #7 |
Stock 1970 axle and hubs, with late model rotors and dual piston calipers. If you're a bit handy, it's an easy conversion and you'll have superior brakes over the early 70's style.
11-30-2017, 11:09 AM | #8 |
More info please...
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
11-30-2017, 03:06 PM | #9 |
There's info on my build thread;
http://67-72chevytrucks.com/vboard/s...d.php?t=676080 |
11-30-2017, 09:02 PM | #10 |
Here are the hubs I have, I will remove the other rotor to ship. If I remember correctly they will fit in a medium flat rate but would need to check again. 50 plus shipping a set, I have 2 sets.
12-01-2017, 03:55 AM | #11 |
Thanks for the reply. I found a set for free today, so I won't need them any more. That is a great price.
12-01-2017, 10:13 AM | #12 | |
Good info here-----> http://77cj.littlekeylime.com/web_rs44.html and here------------> http://www.fourwheeler.com/how-to/tr...sc-brake-swap/http://www.fourwheeler.com/how-to/tr...sc-brake-swap/ You will be further ahead buying a complete front axle and swapping parts from it. |
12-01-2017, 01:18 PM | #13 |
I just did this conversion on my '70 Jimmy a couple of months ago and ran into all kinds of problems. In short, I ended up getting new upper and lower ball joints, inner and outer wheel bearings, seals, hubs/rotors, calipers, brake lines, outer axle shafts, inner axle shafts (because the new ones had different size u-joint holes). It seemed nothing would work together, i had a hard time getting things to work together. U-joints didn't fit both shafts, brake line fittings was different and I had a hard time getting the right adapters... I still have part numbers and websites for companies I found helpfull. If you need anything that I may could help with I'd be glad to offer and info I can
12-04-2017, 03:31 PM | #14 |
I might have to stop by and get a closer look at how you did this when I begin my disc brake swap on my 69.
12-05-2017, 12:40 AM | #15 |
HEMI43 has an awesome fix. I would really look at his setup.
Ok, I just went through a rebuild of a dana 44, I had to replace the spindle and outer axle shaft. Looks like it was in an accident, the bottom of the rotor was ground flat. Also, lol - the PO ground off the end of the axle shaft. I think it was because they could not figure out how to get the snap ring off. Anyways, I did some wrecking yard searching for my parts, it is my understanding that you will need everything from the knuckles out, (including knuckles)... Good news is that the knuckles and everything else is interchangeable between the Dana and 10 bolt. This gives you a fair amount of options to choose from at the wrecking yard. Here is a list I found during my adventure that laid out axle lengths. I just read on another forum that the outer axle shafts between 10 bolt and dana 44 are the same, but the inner axles are different... I am not sure about this. Might be worth your time to go to a Pick-N-Pull. Check this link out as well. http://77cj.littlekeylime.com/flatop_knucles.html Again, Hemi43 has the right idea, just get another axle and swap parts. Let me know how it turns out.
Full top blazer or bust.... |
