Old 11-25-2017, 05:29 PM   #1
Oldrust
Suspension woes
Hey guys,
I’m wondering what I need to do to make my 65’ more drivable. Unfortunately, I just took delivery and I don’t have access to the truck for a few weeks so I’m not 100% certain of its current set up. What I do know is it has 3” drop spindles from CPP, drop springs of unknown specs and its scraping very often to the point where its collected a pretty good pile of asphalt inside the springs. Ride is a bit harsh as well. Will changing to springs with less of a drop lift the suspension and improve clearance? Photo showing the less than 2” of clearance I currently have.
Thanks!
Oldrust is offline   Reply With Quote
Old 11-25-2017, 05:57 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Suspension woes
That
Picture is the perfect example of what not to do on these old trucks.
Combining a drop spindle with a DJM drop pocket a-arm is wrong.
If you would have a flat tire, you'd be sliding on that lower a-arm instead of braking to a safe stop.
Google scrub line.
You need to install a drop spring and use a stock lower a-arm at a minimum.
Keith
Convert to disc brakes.
Old 11-25-2017, 06:03 PM   #3
Oldrust
Re: Suspension woes
Thanks, Keith. PO did all the work, My plan is to make it all correct. You make an excellent point about how unsafe this set up is in regards to a flat. Any particular drop spring you would recommend for a low stance that is safe and rides/handles well?
Old 11-25-2017, 06:19 PM   #4
lolife99
lolife99's Avatar
Re: Suspension woes
I use www.earlyclassic.com for my 67-72 drop parts.
They sell 63-66 parts too.
Give them a call.
If you look at your side view picture, you'll also notice how far back the wheels set in the front fender opening. This is another problem with extremely low 60-66 trucks.
www.pbfab.com sells a-arms that move the wheels forward to correct this look.
Whatever you do get rid of those lower a-arms.
They are old technology, that is no longer needed since they make drop spindles for these trucks.
Keith
Old 11-25-2017, 06:28 PM   #5
Oldrust
Re: Suspension woes
Will do, thanks for the information. And yes, the wheels do seem really far back in the wheel well.
Lower a arms will be history. My plan is to redo/correct and improve the whole truck. I’m also going to be changing the wheels along with the suspension and need to figure out the correct size, offset etc so it all works well together.
Old 11-25-2017, 06:47 PM   #6
Oldrust
Re: Suspension woes
Here are some pics of the rear suspension and more underside shots of whats currently installed.
The Porterbuilt suspension systems look amazing. Something I will consider. Where this truck will be driven has lots of serious mountain roads to deal with. A good suspension is necessary.
Old 11-25-2017, 08:38 PM   #7
PGSigns
PGSigns's Avatar
Re: Suspension woes
What I would do in the front would be put a set of standard lower control arms in the front and do the caster mod at a 1/2" Allows for good alignment specs. Then take a look at the ride height with the springs you have. I think you will need 2" front springs to get back to where you are. The back looks pretty good from the pictures. I would also look at putting a lower profile oil pan on it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-25-2017, 09:28 PM   #8
Oldrust
Re: Suspension woes
Thanks, Jimmy. I just read a bit about the caster mod, seems fairly simple. Oil pan is on my list. Sounds pretty straightforward to get back to safe and normal. I appreciate the comments!
Old 11-27-2017, 02:10 PM   #9
rvrfoot
Re: Suspension woes
Here is mine a arms.Name:  DSCN0830.jpg
rvrfoot is offline   Reply With Quote
Old 11-27-2017, 02:12 PM   #10
Oldrust
Re: Suspension woes
Looks great!
Old 11-27-2017, 02:16 PM   #11
rvrfoot
Re: Suspension woes
I have more pictures if you have anymore questions.
Old 11-27-2017, 02:19 PM   #12
Oldrust
Re: Suspension woes
Thanks! I’m exchanging some emails with Porterbuilt about potentially doing the whole suspension system. I’m after the best handling possible for a 65’ C10 due to the roads I drive on daily i.e. twisty, curvy, steep mountain roads.
How woukd you say your C10 handles/rides with your set up?
Old 11-27-2017, 02:24 PM   #13
rvrfoot
Re: Suspension woes
Mine is awesome, I was happy with mine it sticks to the road. Compared to the stock 66 c10.
Old 11-27-2017, 02:26 PM   #14
Oldrust
Re: Suspension woes
Thanks. What are the details of what you have done? Researching all my options.
Old 11-27-2017, 02:39 PM   #15
Bentbolt
Re: Suspension woes
where is more info on the caster mod? the google brought up every modded c10
Bentbolt is offline   Reply With Quote
Old 11-27-2017, 02:40 PM   #16
rvrfoot
Re: Suspension woes
C notch the rear. Drop 5 in springs 2 inch lower blocks. Front 2 1/2 drop spindles from cpp. Upper and lower arms 2 inch lower coils. Front and rear sway bar.
Old 11-27-2017, 02:43 PM   #17
rvrfoot
Re: Suspension woes
Old 11-27-2017, 02:45 PM   #18
rvrfoot
Re: Suspension woes
Old 11-27-2017, 02:54 PM   #19
Oldrust
Re: Suspension woes
Looks great! Nice stance! Thanks for sharing the deets and photo, very nice C10!
Bentbolt- I googled and found multiple threads right here on this forum. It involves drilling the lower control arm to allow more caster than the factory spec which many say is much better in terms of steering feel.
Old 11-27-2017, 03:00 PM   #20
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Suspension woes
Her you go - http://67-72chevytrucks.com/vboard/s...d.php?t=501241
Old 11-27-2017, 03:24 PM   #21
rvrfoot
Re: Suspension woes
I will need to check on mine. I think the arms on mine gives it 2% more caster.
Old 11-27-2017, 05:06 PM   #22
Mack B
Mack B's Avatar
Re: Suspension woes
Originally Posted by rvrfoot View Post
Where did this sway bar come from? Looks like it may be what I need.
Mack B is offline   Reply With Quote
Old 11-27-2017, 05:11 PM   #23
rvrfoot
Re: Suspension woes
cpp in cali works great.
Old 11-27-2017, 05:53 PM   #24
theastronaut
theastronaut's Avatar
Re: Suspension woes
Are you keeping the 15" wheels? If so there's no need to go all out on the suspension, you'll run out of tire before you need any kind of serious suspension tricks.
On my '66, I did 2.5" spindles, cut 1.5 coils off the stock springs, used stock control arms with the bump stop brackets cut off completely, and relocated the upper shock mount farther up the frame to get full shock travel. Also added a CPP 1.25" sway bar and KYB Gas-Adjust shocks.
On the rear I did a small pipe notch, 5" springs and 1.5" drop blocks, did FrizzleFry's easy/free shock relocation with gas shocks (front fitment) from the parts store, and a mid 80's F150 rear sway bar. Getting the shocks outboard of the frame and standing them straight up instead of laid over at an angle helps them work much more effectively.
Your rear suspension looks pretty good already, but I think you'd benefit from relocating the shocks outward. Link to the shock relocation how to-
http://67-72chevytrucks.com/vboard/s...postid=4730005
My truck rode as good as dad's all-stock '66 without the truck pitching excessively over larger bumps due to the lower center of gravity and the shocks and sway bars controling the body movement better. It cruised dead steady on the interstate even over 90 mph and had less body roll than my autocross car. The tires were the limiting factor of how hard I could push the truck around corners, it would have done much better on 18's with shorter sidewalls.
theastronaut is offline   Reply With Quote
Old 11-27-2017, 08:03 PM   #25
Mack B
Mack B's Avatar
Re: Suspension woes
Thank you, sir
