Old 11-25-2017, 06:07 PM   #1
nrb's70gmc
nrb's70gmc's Avatar
Is This normal? Blowing brake boosters
Quick rundown i baught my truck in 2001
i replaced the brake booster that i baught the truck with,(it failed) (around 05-07) cant remember exactly what year. it was a napa replacement booster listed for a 1970 gmc 2500.
ive been having a hard brake pedal for a few months now. and braking perfromance sucks.
when the brakes are acting normal i can lock them up (not possible now)
i checked the vacuum line
i pulled the line off the booster and hear the air (motor almost dies-plug with thumb) and retures to idle)
it seems to me i need a new booster. is this normal replacment (in years from when i replaced it before) or is it premature failure?
1970 2wd 3/4 ton- 2004 crate 350 thorley tri-y headers-edelbrock performer eps manifold 600cfm performer carb, crane cams energizer cam,lifters, dual 2.5 magnaflows, mallory HEI, powermaster 140 amp altenator, griffen aluminum radiator.(8 MPG)
nrb's70gmc is offline   Reply With Quote
Old 11-25-2017, 06:18 PM   #2
notsolo
notsolo's Avatar
Re: Is This normal? Blowing brake boosters
Quality of replacement parts is not what it use to be! ....Bought some front brake hoses from Napa a couple weeks ago....Chinese crap....I would think a booster would last 20 yrs.
notsolo is offline   Reply With Quote
Old 03-27-2018, 08:30 PM   #3
Liteman504
An easy check for brake booster is to hold your foot with pressure on brake pedal. Start engine ,if pedal goes down further when engine starts the booster is working correctly.
T
Liteman504 is offline   Reply With Quote
