Old 11-26-2017, 02:04 AM   #1
ghalperin
ghalperin's Avatar
Brake questions for experts
I’m still pretty green as far as actually driving these trucks.
Last week I was traveling about 35mph and someone cut me off. I slammed on the brakes. It did stop, but I’m pretty sure that the rears locked up. The bed was empty.
Is that normal?
Everything is new:
ECE front stock rotors and calipers.
New stock non-power master cylinder
CPP proportioning valve
New stock rear brakes
Glenn
1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca
1929 Ford Model A Roadster - traditional pre-war banger hot rod
ghalperin is offline   Reply With Quote
Old 11-26-2017, 03:38 AM   #2
Rannoch
Re: Brake questions for experts
Sure?
I've only had to emergency stop once in my truck (empty bed) and I locked up the rears.
Rannoch is offline   Reply With Quote
Old 11-26-2017, 06:08 AM   #3
Grumpy old man
Grumpy old man's Avatar
NO ABS ,So what happened to you was a normal emergency stop with an empty bed , Now when all four wheels lock up and you slide off the side of the road ,That's a panic stop !
Normal operation for a 50 year old empty truck .
Grumpy old man is offline   Reply With Quote
Old 11-26-2017, 09:11 AM   #4
ghalperin
ghalperin's Avatar
Thanks for the feedback, I figured it was normal.
Glenn
Old 11-26-2017, 09:36 AM   #5
Alex V.
Alex V.'s Avatar
Yes, normal.
My BIL's IH 1110, with manual drums, would lock the fronts up solid if you stomped it.
The other day in my (new to me) '82 Mercedes I stayed into the gas a little long before changing my mind on a yellow light. I guess I'm too used to either ABS or vehicles too old/heavy to lock up the brakes on dry pavement, 'cuz after much sliding and veering I got 'er stopped 2/3 of the car over the line!
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 11-26-2017, 10:25 AM   #6
Grumpy old man
Back in the day if you were sitting at a traffic light and heard screeching brakes form behind you the first thing you did was check your rear view mirror to see if they might be able to stop before hitting you ! Brace for impact , it was a common thing to see drivers who had facial injuries from smacking the steering wheel face first wearing just the lap seat belt . and passengers from hitting the dash or windshield .
