Need help to identify my engine
Need help to identify my engine.
It is a 6-inline and is installed in a 1952 GMC 253-22, but I'm pretty sure it is not the original engine. I found a number located directly beside the engine oil dip stick. Number is: B228370750 maybe the last digit is a C instead of the 0. Thanks Martin |
Hollister Road Co.
Re: Need help to identify my engine
post a picture of each side and the valve cover
The number comes out to a 1952 228 cubic inch GMC motor |
Thanks.
I had read that there is a 216 installed in the 1952 GMC 253-22. But it seems to be wrong. Nevertheless I will takesome photos of the engine and will post them tomorrow |
Hollister Road Co.
216 is chevy motor. GMC had its own truck motor until the early 60's
if it is a 216 then its not original |
#5 | |
![]() Join Date: May 2007
47-5? GMC got 228, 248 or 270 cubic inch engines, never got a 216. dwcsr is right, the first three numbers tell you the engine displacement of a GMC motor, the leading letter is the main bearing clearance corresponding to a list. your engine number to me indicates its the original engine, replacement GMC 228 are usually zero'd or X'd out or just plain blank past the displacement.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#6 | |
Hollister Road Co.
#7 | |
I just took apart a 49 GMC with a 248
Hello!
Here are the photos I have taken today. I guess it is the right, maybe original, engine. The manual, where I had read the normal engine size for 1952 GMC pick up is 216cui is definately wrong Martin |
Here the number I found on the engine
Hollister Road Co.
Definitely a 1952 GMC 228
The problem with identifying GMC is that they didn't go strictly by year like Chevy did. They used serial numbers not VIN numbers that would fall in a particular year. B228370750 was 1952 but B228370749 could have been 1951 and register both as 1952's or 1951's depending on what state or country it was registered in. |
I Also Need Help Finding My Engine Number On My 1987 R 10 Silverado 5.7
I Need The Location Of The Number Thank You For Your Help In This Matter Harley03joe ![]() ![]() ![]()
1931 Ford Like New And For Sale ![]() 2004 Harley Davidson Heritage Classic 1987 Chevy R 10 Silverado 2007 Azera 2011 Cadillac CTS Premium |
