11-27-2017, 08:56 PM | #1 |
Diff help
Will they differential out of a 2000 plus Chevrolet 2500 fit into a 71 Chevrolet C20 I know I have to change the axle mounts and track bar is there anything else.
11-27-2017, 09:10 PM | #2 |
Re: Diff help
shock mounts. It should work. You will need proportioning valve and master cylinder change if it is a disc brake rear and parking brake cable mods.
Honestly the drum brakes are fine and an easier swap. When I did the semi-float 14 in my Jimmy, I removed the Suburbans parking brake cables and replaced with the original ones from my 12 bolt. I used the Suburban spring pads (leaf springs on my truck) but used the original shock mounts.
11-27-2017, 09:20 PM | #3 |
Re: Diff help
I used a FF 14 bolt out of a 2004 Chevy 2500. The width pushes the wheels out a bit but I was using the late model wheels with more back spacing.I also used the drivers side E-brake cable from a 2013 tahoe to hook up the E-Brake.Passenger side is too long so I got two drivers side cables. Worked like a champ.
11-27-2017, 09:21 PM | #4 |
Re: Diff help
Ok thank you very much
12-27-2017, 10:03 PM | #5 |
Re: Diff help
Were did you get your purches
12-27-2017, 11:08 PM | #6 |
Re: Diff help
Speedway Motors has a kit and I bet ECE does as well in addition to others.
12-27-2017, 11:56 PM | #7 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Diff help
PM Captainfab here on the board for axle pearches. way better than anything else out there. Stronger and a bit larger than others and laser cut fit as well. He makes all the brake parts for calipers, panhard bar mounts, and hydrovac mounts as well. Top shelf products fabbed to fit our trucks...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
12-28-2017, 08:50 AM | #8 |
Re: Diff help
Good to know about CaptainFab. And he may be able to make some for you for different diameter axle tube. I know the semi float 14 in my Jimmy is 3.25” tube and not the 3” the 67-72 trucks are. Not sure about the housing that you are looking at. It may require you to elongate the holes on the trailing arm and source some different u-bolts as well.
12-28-2017, 11:51 AM | #9 |
Re: Diff help
Thank you I pm him today
