Old 11-27-2017, 08:57 PM   #1
weshuseby
67 chev truck tire sizing
i am building a 67 chev truck and looking to ideas on tire sizing choices we have tubbed the rear inner fender wells and looking at putting as big of tires as possible. i am thinking of putting 20x12 rims and Mickey Thompson 29x15x20 tires has anyone had experience doing that and any advice would be appreciated
weshuseby is offline   Reply With Quote
Old 11-28-2017, 12:49 PM   #2
bmfpeterson
bmfpeterson's Avatar
Re: 67 chev truck tire sizing
I have a set of 29x15-20 on my truck.... Had to measure for backspacing and the wheels were built off of my specs.
bmfpeterson is offline   Reply With Quote
Old 11-28-2017, 04:29 PM   #3
BossHogg69
motor exploder
BossHogg69's Avatar
I've got 19x12's, 6" b.s. w/345/30/19's on mine, so I can't really offer any advice on 20" tires, not to mention I also narrowed my rearend ('69 C10 housing). I will say make sure you have the bed put together and preferably bolted down on the frame as the truck will go down the road when YOU do the measuring. You are getting into a custom made wheel to get the backspacing right - you're looking at 7-7.5" bs on the rear with the stock width '67 rear and stepside bed, depending on how you want it to 'tuck'. But things with vary from truck to truck here and there when it's all bolted together. I dang sure wouldn't take a bunch of ppl's opinions from the 'expert' laden interwebs to order my wheels. You won't be able to return your shiny new high dollar custom backspaced wheels if you're off on the numbers...
BMF Peterson - your setup looks good!
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 11-28-2017, 07:29 PM   #4
weshuseby
that is exactly what I'm looking to do with mine what rim size is yours and what back spacing did you use just so I'm in the ball park when i measure mine. and if you don't mind me asking what brand of rims are those. PS your truck looks great
Old 11-30-2017, 03:22 AM   #5
bmfpeterson
Thanks guys!
As far as measurements I would have to look into it to find out I'm not sure off the top of my head. I would guess around 6 inches of back spacing but i will check and let you know to give you an idea. But I also agree that you just plain have to measure your setup cause they are all different. I've seen 18" wides on these trucks so I know it can be done.
Just thought of it but I'm pretty sure if your rear end came on your 67 it is narrower than my 71 by an inch or so.... that helps too
Old 11-30-2017, 11:46 AM   #6
bmfpeterson
Just looked up my receipt and it shows 7.5" backspacing. I'm just finishing my shock brackets for the rear and then I am going to put my bed on and I will post pics.
Old 11-30-2017, 01:51 PM   #7
weshuseby
thanks for the info our measurements showed we needed 7.5-8 in back spacing also so we are in the ballpark. what tires and rims did you use on the front we are thinking of going with 26x10x18 on the front with a 5.25 back spacing and same tires as you on the back on 20x12 with 7.5 in back spacing on the rear i think these numbers work but just wanted to see if others had made this combination work. Mine is not a true 67 we are just using 67 parts to make it have the look we want it is actually a 71 i believe. thanks for you time
Old 01-01-2019, 03:42 PM   #8
Robznob11
Robznob11's Avatar
Are these rear rims 12 wide or 14? The web site says you need a 14 wide wheel for that tire...
Also what size wheel and tire you have up front?
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
