11-27-2017, 10:36 PM | #1 |
Thoughts on water/methonal injection.
My 84 K30 is equipped with a 454 and sm465, It is currenty my daily driver so I am trying to get the best mpg out of it that I can. I put a edelbrock 600 cfm carb on it and that helped some I think but what is the consensus of adding a water/methonal injction setup? Ive read that it helps promote power and mileage but I cant find any articles online that help me find my answer.
1956 Chevy 3600 Napco 1984 Chevy K30 - 454 |
11-28-2017, 01:51 AM | #2 |
Re: Thoughts on water/methonal injection.
Water does not burn, it just cools the intake charge and cleans the combustion chamber. Most likely would not help mileage.
11-28-2017, 08:26 AM | #3 |
Meth is mostly used to control detonation on boosted engines . As grady said it cools the chamber
The first thing most don't look at is your air fuel ratio . You can put a smaller carb on and still have gained nothing ( most all carbs run rich ) . It all depends on air fuel and the tuning of the carb at part throttle and cruise . Get a a/f gauge if you really want to know where your at and do some research on carb tuning . There is a lot to tuning a carb and is rewarding if you take the time to learn . The other alternative is an efi system . The a/f gauge is a valuable tuning tool even if you go efi. But remember you have a lot of cubic inches and a lot of weight to move around . If you are running afr of 10.5 there is plenty of room for improvement . But no way to know this without the proper tools . Just something to think about . |
