Old 11-28-2017, 01:13 AM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Painting axles - frames too
My axle is just resting on a $16 Harbor Freight furniture dolly. Serves it's purpose, and the more I think about it, seems just as well to use it for paint. I could strap the axle to my engine hoist, but either way I have to hit what I missed following assembly.
Unless talked out of it, I plan on using sponge rollers anyway, so touch up is easy. Same on the frame, using MasterSeries and their satin top coat....................I've read it comes out real nice with a sponges. If I understand it right, the results are even better than through a gun, though I'm not sure that includes the top-coat. Masters recommends sponges for the primer coats.
I'm looking for a real nice finish to go with a un-pitted & blocked frame. I'm good with a brush, but I don't know, perhaps the top coat through a gun will look cleaner.
Here's someone's frame with MasterSeries. Can't say if brushed or sprayed. https://s20.postimg.org/8wszjd6p9/image.jpg
Other than that, how have you painted an axle, or frame?
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 11-28-2017, 02:29 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: Painting axles - frames too
Set the axle on a set of jack stands to paint ,works great .
This frame was painted using a $16.00 gun from harbor freight using tractor supply paint with the catalyst hardener , Less than $50.00
https://www.tractorsupply.com/tsc/pr...l?cm_vc=-10005
Grumpy old man is offline   Reply With Quote
Old 11-28-2017, 02:33 AM   #3
71CHEVYSHORTBED402
If I recall, you've used master series as well. That frame looks GREAT. Might be a foolish question, did you use primer? What primer?
Tony
Old 11-28-2017, 12:30 PM   #4
ghalperin
ghalperin's Avatar
3 jack stands and then flip the axle over. I put lug nuts on the studs and had the nuts sitting on the stands.
I used a "disposable" gun from Harbor Freight. Less than $10 when on sale. I did clean the gun a few times when I was going to spray again on the same day, but beyond that it's not worth the aggravation of it not working correctly.
I used Magnet Chassis Saver chassis paint in satin black. Only buy as much as you can use, it doesn't store well after opened. After use, clean the rim of the can real well or you won't get the lid off. I used less than a gallon for everything. Per the instructions, I didn’t prime. If you use this paint, order the S8 reducer at the same time. It is MEK and is outlawed in most states, you won't find it local, but you can get it online. I bought both paint and reducer on eBay, for around $100.
Wear a respirator, I didn't the first day and even though it was out doors, I still puked for 3 days.
Using the gun and spraying the paint was simple. This was my first time doing it and it was much easier than I thought it would be.
http://www.magnetpaints.com/underbody.asp
https://m.harborfreight.com/20-oz-8-...gun-67181.html
Glenn
1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca
1929 Ford Model A Roadster - traditional pre-war banger hot rod
ghalperin is offline   Reply With Quote
Old 11-28-2017, 01:11 PM   #5
notsolo
notsolo's Avatar
Mastercoat silver lays down nice with 1.8 tip and 10% reducer. Might want to test your sponge with the Mastercoat, I found it melts painter pads and foam rollers. Cloth rollers work ok. Repackage Mastercoat in jar or smaller can if you are going to keep it for more than a week.
notsolo is offline   Reply With Quote
Old 11-28-2017, 05:41 PM   #6
RodnRudy
RodnRudy's Avatar
When I painted my rear end I bolted a brake drum on backwards and stood it on end. I sprayed it with East Wood chassis satin black using their aerosol cans. It worked out really well.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 11-28-2017, 07:48 PM   #7
crazyjeenyus
crazyjeenyus's Avatar
I used POR-15. Its great and hard as heck, but don't let the sun get to it, it'll fade and lose it's strength properties. I painted my wheels with it and they're pretty faded now.
'67 c10
'65 c10
crazyjeenyus is offline   Reply With Quote
Old 11-28-2017, 08:12 PM   #8
71CHEVYSHORTBED402
Some great ideas. I think I'll do it as Grump's suggested. Seems to me the gears remain in tack with the pinion and gears pin in place, so just as well let it hang down. Spent 3 hours today doing just that to clean the axle. Second cleaning and more to go. No surprise to those who've done this, the axle has caked on grime where the lower U-bolt plate seats for leaf springs. Got half of it. Penetrating oil soaked rags should do it.
Great idea with that frame ghalperin's. I see Harbor Freight has engine stands pretty cheap. $170ish gets you a rotisserie and cart. Existing bolt holes lined up? What you guys figure a SWB frame weighs?
Interesting, because they recommend sponge applicators for the primer coat. More I think about it, more I think I'll spray. Thanks for the tips.
One of the differences between MasterSeries and Por15 is Masters can take the sun exposure.
Tony
Old 11-28-2017, 08:27 PM   #9
71Charlie10
I bolt a rim and tire to one side, stand it up, cover the rim and tire if it is important and go to town.
Nic
71Charlie10 is offline   Reply With Quote
Old 11-28-2017, 09:18 PM   #10
original-71
///Relaxed Atmosphere
original-71's Avatar
you have to use a top coat when using por 15. I went with john deere blitz black as my top coat
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R)
87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R)
hector
_________________________________
1971 Chevrolet Cheyenne Super
1987 Chevrolet Silverado
2006 Ford Mustang GT
2012 Toyota 4-Runner
2014 Dodge Ram 1500 Sport Crew Cab
original-71 is offline   Reply With Quote
Old 11-28-2017, 10:16 PM   #11
Mike C
Mike C's Avatar
You definitely want to spray the frame. We just did a Blazer frame for my kid's Jimmy project. I used the Summit Chassis Shield black.
The Harbor Freight gravity feed gun works awesome. Especially for $10! I've used mine several times and when it won't clean easily at some point, I have a couple of backups!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 11-29-2017, 11:49 AM   #12
notsolo
notsolo's Avatar
Break out the good respirator for the Mastercoat, I use B/C right over it also with no problems.
Old 11-29-2017, 12:34 PM   #13
ghalperin
ghalperin's Avatar
That's a good idea.
Glenn
Old 11-30-2017, 02:04 AM   #14
ripper70
ripper70's Avatar
I used POR 15 and there chassis coat black as a top coat. Used a foam pad and it turned out good
1970 K20
1967 Blown Stepside
2016 Chevy 2500 Duramax
1989 Jeep Cherokee
1995 S-10
2014 Infinity Q-50 AWD
1970 Chevy K20 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=634164
1967 stepside rebuild
http://67-72chevytrucks.com/vboard/s...d.php?t=684913
Shop build http://www.garagejournal.com/forum/s...d.php?t=225559
ripper70 is offline   Reply With Quote
Old 11-30-2017, 02:17 AM   #15
Richard2112
Richard2112's Avatar
I use aerosol spray bed liner. Tough stuff
Richard2112 is offline   Reply With Quote
