Old 11-28-2017, 10:56 AM   #1
Bmstd
Bmstd's Avatar
Lowest Static Drop (But Functional)
I am starting on a new project where we are converting C60 to C10. We have an original 8000 mile fire truck tanker and are repurposing cab, hood, engine, and transmission to assemble a c10 swb.
For the chassis we want to stay with static drop, but wanted to call on some of the experience out there.
What is the lowest drop that can be done and still be "driveable" using static lowering parts?
We want to stay traditional and not cut up frame (other than c notch) if possible.
Can anyone share what has worked for them or are using currently including what manufacturers?
Bmstd is offline   Reply With Quote
Old 11-28-2017, 11:43 AM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: Lowest Static Drop (But Functional)
With out c-notch 3/4 drop, lower than that you can't carry anything with out bottoming out.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 11-28-2017, 03:40 PM   #3
62 short step
62 short step's Avatar
My truck is 5 1/2 in the front and 6 in the rear.
It could use a c-notch for the rear.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 11-28-2017, 04:37 PM   #4
scoot_mcgrute
5/7 here. Plenty usable but I do need to install that c-notch as I only have roughly 3/4" uptravel. I only hit on big bumps though.
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 11-28-2017, 09:25 PM   #5
PGSigns
PGSigns's Avatar
Mine is 4 1/2 front and 5 1/2 in the rear and it is my daily driver and I use it as a truck.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-28-2017, 11:10 PM   #6
PatJ
CPP drop spindles and drop springs
Porterbuilt C notch and rear drop springs
Not as low as I would like but its got a full bed and still fully functional.
Pat Jones
Cary, NC
64 Custom Cab Fleet
PatJ is offline   Reply With Quote
Old 11-29-2017, 09:00 AM   #7
raidmagic
raidmagic's Avatar
Do any of you haul a trailer? This is on my list of things to do.
raidmagic is offline   Reply With Quote
Old 11-29-2017, 10:00 AM   #8
62 short step
I don't, but if it was bagged maybe I would.
1965 c-10
86 chevy c/k 20
Old 11-30-2017, 01:48 PM   #9
Magnimike1
I just bought a truck with a smash-hit bumper. Cool truck
Magnimike1 is offline   Reply With Quote
Old 11-30-2017, 04:06 PM   #10
The Mule is a 4 1/2 front and 6" rear. No C-notch. I have carried things, but you must go REAL slow and careful to not bottom out. I plan on a c-notch some day, I just have not stopped driving it enough to take time to do it.
Old 11-30-2017, 05:49 PM   #11
62 short step
Thanks!
1965 c-10
86 chevy c/k 20
Old 12-04-2017, 12:43 PM   #12
raidmagic
raidmagic's Avatar
Great stance
Old 12-05-2017, 03:59 PM   #13
theastronaut
theastronaut's Avatar
Somewhere around where my old '66 sat was about as low as you can go static and still be drivable. There was only 1.5" between the inner fender and top of the front tire, and about 3" before the crossmember bottomed out. Small pipe notch in the rear, shorter than a bolt in notch to keep more frame strength. The diff will hit the bed floor before the axles use up all of a bolt-in notch, so I'd rather have a small pipe notch that keeps more of the frame rail height.
theastronaut is offline   Reply With Quote
Old 12-06-2017, 11:51 PM   #14
Bmstd
Bmstd's Avatar
Thanks everyone for your input. I really like the stance of theastronaut has on the 66. I am going to try to get in that low of a zone with static drop.
For what i want to accomplish, I think i will start with 2 1/2" drop spindles and then 3" drop springs out front. I may even get way over the top and order set of PB 1" narrow and 1" forward A-Arms to correct angles. In rear it sounds like 5" drop spring and up to 2" block will work the best. Looking at Dead End Garage C-Notch and track bar combo if i need the additional clearance for suspension travel.
