Old 10-30-2003, 10:17 PM   #1
FRANKIEPOTATAS
Problems..........GOTTA LOVE EM!!!!!
ok....... so now that I just swapped a 71 front crossmember into my 69 for the front disks....... bought 6 lug rotors to keep the stock look for my 69 and after a lot of beating to fit and painting to match I stumbled across this most fun challenge....... my stock 6 lug rim wont fit because the caliper hits it.....now isn't that fun!!!! Has anyone come across this before and if so, what did you do to combat this? I like the stock hubcap look to keep the truck a "sleeper" but should I just break down and buy a set of rims? Also does anyone have the exact numbers height, width, backspacing,on rims that fit without PROBLEMS!!! Also if I choose to go with a set of rims I want to try 17's.... if anyone could pass along proper dimensions of rims that fit would be much appreciated. Hey and if anyone has rims that will work for sale as well...... pass that along as well.... I may snag them. thanks
FRANKIEPOTATAS is offline   Reply With Quote
Old 10-30-2003, 11:01 PM   #2
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
I heard that this would happen with the stock wheels, I didn't have that problem because I have 6 lug rally wheels. My wheels are 15x8 with 4.5" backspace. You will clear with no problems!
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 10-30-2003, 11:01 PM   #3
Tim Christian
Tim Christian's Avatar
Smile
I have 15x7 rallys on the front of my 6-lug disc but had the same problem the stock rims will not fit.
Tim Christian is offline   Reply With Quote
Old 10-30-2003, 11:03 PM   #4
Hotrod70C10
Low & Slow
Hey Tim, We posted at the same time! lol
4.5/6 drop
Old 10-30-2003, 11:15 PM   #5
Tim Christian
Yes, I seen that! LOL I still have not forgotten about your question on the 6-lug rotors. But I can not never remember to ask them. LOL But I will.
Old 10-31-2003, 05:41 AM   #6
Truck Hippy
Truck Hippy's Avatar
You should be able to just use stock steel 4x4 wheels for 71-up.
Truck Hippy is offline   Reply With Quote
Old 10-31-2003, 06:18 AM   #7
Hotrod70C10
Low & Slow
Hey Tim! good memory there! lol.... I forgot all about that!
See people that is why Tim is a stand up guy!
4.5/6 drop
Old 10-31-2003, 11:48 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I am not a huge fan of spacers, but if your lugnuts are long enough, they'll do the trick.
Old 10-31-2003, 11:55 AM   #9
CPNE
Resident Curmudgeon
CPNE's Avatar
This is the best solution, 71-up 1/2 ton 4x4. They are 6 lug and designed for disk brake front ends.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 10-31-2003, 12:14 PM   #10
FRANKIEPOTATAS
Thanks for the input guys.... was also wondering what width of a 17 " rim would fit in the front with no problems? I was thinking about a 17 x 7
Old 10-31-2003, 02:38 PM   #11
Hotrod70C10
Low & Slow
I would think that a 17 inch wheel with a 4.5 inch backspace would work. You will not have any interferance with the caliper or rotor with a larger diameter wheel so, You just need to get the right backspace.
4.5/6 drop
Old 10-31-2003, 03:06 PM   #12
Professor
Back in my tractor and truck pulling days (before it got nuts with the high-dollar sponsored guys), I used to run a 3/4 ton Ferd. (By the way, I can tell you the maximum RPM that basically stock big-block Ferd valve springs will take just before they break.) It had factory 16 inch 8-lug wheels. I made some 15 inch rims from old 8-lug 15 inchers by splitting them in half and welding in 2 inch flat stock to make them 2 inches wider so I could 15 inch tractor-lug type tires from a hay swather. (Hey, it was cheaper than buying new wheels and I taught welding!) Well, the 15 inch rims hit the corners of the calipers a little. 10 minutes and a right-angle grinder on the caliper took care of that.
(Legal disclaimer: it won't work if you have to grind too much. Don't compromise the integrity of your caliper.)
Professor is offline   Reply With Quote
Old 10-31-2003, 03:19 PM   #13
mcmlxix
Collector of Projects
mcmlxix's Avatar
I have 17x8.5 Impala SS rims on my tuck. They fit nice and dont rub. I have 275/55/17 tires on all 4 corners...but I am running the sock 5 lug (71 C10)
Rich
1972 K5 Blazer CST Click HERE
Old 10-31-2003, 05:19 PM   #14
FRANKIEPOTATAS
thanks Professor but grinding the calipers are not a option I wish to take at this time
Old 10-31-2003, 05:31 PM   #15
Frank_Zeller
Frank_Zeller's Avatar
see this post..some interesting info on rims
http://67-72chevytrucks.com/vboard/s...threadid=73572
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 10-31-2003, 10:50 PM   #16
Hooter
My other Love
Hooter's Avatar
I got the disc brake conversion from early classics, I am running 6 lug ralleys off a 74 chevy 4x4 with no problems
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
