Old 11-29-2017, 10:33 AM   #1
cwilkie
Chance
cwilkie's Avatar
MSD Atomic stock gas tank
I’d like to install my second MSD Atomic Efi in my 1972 with return line. I want to leave the gas tank where it is at since I have a receiver hitch installed where a rear mounted gas tank would go.
Anyway, would I be able to do this with a stock tank? Does anyone have any ideas on my options to get it installed?
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 11-29-2017, 12:11 PM   #2
FRCvette
Re: MSD Atomic stock gas tank
I am installing a Holley Sniper on my 70 with stock tank this weekend. I bought a Edelbrock sump that mounts the fuel pump under the hood. No return line needed. Does have a vent line that needs to go to tank or charcoal canister. I bought a 72 fuel sender to run it to.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline   Reply With Quote
Old 11-29-2017, 12:18 PM   #3
weq92f
weq92f's Avatar
Stock tank with Atomic should work. I would use the under hood sump type fuel system though just to keep the noise down!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 11-29-2017, 12:36 PM   #4
cwilkie
Chance
cwilkie's Avatar
Noise is not an issue. In the area where I live I need to use a return line. So fuel senders have a return line port?
BB 396 w/TH400
BB 496 w/TH400
Old 11-29-2017, 01:38 PM   #5
FRCvette
71 and72 does. Extra port was emissions. I believe noise level that weq92f was referring would be from fuel pump if installed in tank.
2004 SSR
2013 Silverado swb
Old 11-29-2017, 01:41 PM   #6
FRCvette
This would be the sump I am referring to. I purchased thru Summit.
http://www.edelbrock.com/automotive/...ages/36031.jpg
2004 SSR
2013 Silverado swb
Old 11-29-2017, 07:23 PM   #7
cwilkie
Chance
cwilkie's Avatar
Keep them coming guys. Just looking for advice on what will work with my application. I have the full MSD Atomic Master kit already. I just don’t care to move my gas tank to the rear on this truck since I mainly use it for work and pushing snow.
BB 396 w/TH400
BB 496 w/TH400
Old 11-30-2017, 10:06 AM   #8
clay68c10
clay68c10's Avatar
Just run an external pump under the cab. It’s low enough below the tank to do fine.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 11-30-2017, 11:18 AM   #9
cwilkie
Chance
cwilkie's Avatar
I was planning on running the external pump and return line from msd. I just need to know if there is a port on the stick gas tank for the return line. Do I have to change the fuel sender to one with an additional port if there is no port on the gas tank?
BB 396 w/TH400
BB 496 w/TH400
