Anybody Redo Door Panels ??
Anybody out there recover door panels? Or where to send them? To match leather bench seat..
![]() Join Date: Dec 1999
Re: Anybody Redo Door Panels ??
Had visors, seats, door panels, headliner done at a local upholstery shop. They have access to a large selection of materials. And could probably match the seat.
Smitty '71 Short Fleetside Spring Valley, Ca. |
Nailed It! Wow your upholstery guy did a fantastic job on that.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
Old member
I've done 3 sets for my 71 & 67 both. 2 for the 71 & 1 for the 67. I bought 99 Tahoe seats and recovered them plus added heat to them. I also did the dash and steering wheel myself. The door panels I bought the backing board took it home made the pattern and then had the local upholstery guy cover them. I did the same thing to the 67 on the door panels not the other stuff.
What I have now in the 71. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I currently do not have door panels, but bookmarked this ebay seller for a possibility when I look into putting some on.
https://www.ebay.com/usr/rrachal11 I guess they can make door panels in vinyl for $100. You could always contact them for other materials or options.
Project Engine Stand 1972 SWB conversion: http://67-72chevytrucks.com/vboard/s...d.php?t=673914 1970 Nova: http://67-72chevytrucks.com/vboard/s...d.php?t=708161 |
Took the original panels, removed the raised section (1972) and had a friend re-upholster them. Also had the headliner done with a matching pattern.
Active Member
![]() Join Date: Jun 2016
My regular steel door panels seem like they're bent inward. Is the mating surface supposed to basically be flat? I'd like to recover them but they're so wonky makes about 1/2' to an 1" gap between the handles and the panel. Thinking about just getting new ones.
David Larsen 1970 Chevrolet C-10 |
#8 | |
I had this done to my 72 panels, dash pad and visors to match the buddy buckets. Board member crsweet91 did it. Don't know if he's still around. Haven't seen him post on here in along time.
For some people driving is one long series of corrections... |
#11 | |
