Old 11-30-2017, 02:56 AM   #1
andrewpclayton
andrewpclayton's Avatar
Wiper motor is getting power but wipers won’t work.
New motor? New link assembly?
1977 SWB (c20 conversion) SBC350
Springfield Oregon
Instagram: @nevernotchevy
andrewpclayton is offline   Reply With Quote
Old 11-30-2017, 02:56 AM   #2
andrewpclayton
Re: Wiper motor is getting power but wipers won’t work.
Actually having same problem with the heater blower motor as well.
Springfield Oregon
Old 11-30-2017, 08:38 AM   #3
Barnfind46
Barnfind46's Avatar
Because you have two things not working I would start with the wipers. Check all the fuses,then the grounds.Then make sure the contacts in the plug are clean with no corrosion.If still no good,check the wiring diagram to find which terminal is power on the wiper motor and run a jumper wire from a 12 volt battery. If the motor runs it will be the switch.If this fixes the wipers but the blower motor still does not work,I would do the same with the blower motor. Hope this helps.
Barnfind46 is offline   Reply With Quote
Old 11-30-2017, 10:34 AM   #4
Wrenchbender Ret
The wiper motor is grounded through the switch. If you have power to it try jumping the wire to the switch to ground. If the motor gos the problem is in the switch. Trace the heater wire with a test light. It should have current going to it when the ign. is turned on & the heater switch turned on.
George
Wrenchbender Ret is offline   Reply With Quote
Old 11-30-2017, 11:35 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
I would check the ground straps from the engine and the frame, to the cab first to make sure the cab is grounded good. If you don't find any ground straps add some. Read the thread "Testing Windshield Wiper Motors" that is down below this one a ways.
LockDoc
Leon
Old 01-02-2018, 10:10 PM   #6
andrewpclayton
the entire unit was getting power, and i found that the wipers work if i help them along sometimes with a little force. I used a whole lot of WD-40 on every connection on the linkage and that seemed to work. they have been working the last 6 times i have tried and they seem to be moving pretty well. thanks!
Springfield Oregon
Old 01-02-2018, 10:43 PM   #7
custom10nut
custom10nut's Avatar
Grounds and continuity are the secrets to success with these trucks. Make sure all your grounds are making contact and put dielectric grease on all your contacts
custom10nut is offline   Reply With Quote
Old 01-02-2018, 11:01 PM   #8
custom10nut
