Old 11-30-2017, 01:38 PM   #1
landarts
landarts
Help with Big Block Valve cover item
I am in the process of getting this K2500 4x4 with a big block motor road worthy. I admit I don't know much about the motor and am trying to figure out what the item in the picture on back side of valve cover is for. I know that the drivers side valve cover grommet needs the PVC valve, the passenger side front is the oil fill cap. Just trying to found out what the back passenger side on the valve cover is for and what to do with it.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 11-30-2017, 01:55 PM   #2
kwmech
Re: Help with Big Block Valve cover item
There is a spacer missing that has a tube coming out the back of it that connects to the screen in the valve cover
Old 11-30-2017, 02:32 PM   #3
landarts
landarts
Does anyone have a picture of it?
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 11-30-2017, 03:02 PM   #4
MusicMan70
MusicMan70's Avatar
Found this photo from a low mileage fire truck ad.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 11-30-2017, 08:16 PM   #5
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Carb. spacer & flame arrestor: The spacer sits on top of the carb. base gasket. A 3/4" ID hose runs between the spacer and flame arrestor. This hose is approx. 5" long. The flame arrestor inserts into the RH (TS) valve cover using a grommet. The hose is retained using two 1.1/4" tower clamps.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 12-01-2017, 08:36 AM   #6
engineer_gregh
engineer_gregh's Avatar
I think that is part of an emissions control system used on later model motors. 4x4 trucks were not offered with big block engines, the fact that the alternator is on the passenger side suggests to me that the motor is 1976 or newer, just my .02 cents.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 12-01-2017, 01:13 PM   #7
71CHEVYSHORTBED402
Seems right. Might be a 454. I don't recognize the part in the OP. Perhaps it's 1976ish as well.
Tony
Old 12-01-2017, 05:44 PM   #8
landarts
landarts
good point, I will get the numbers off the block and run the numbers to see what motor it actually is. Thanks!
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
