C10 CLUB Y QUE!
Heat and air
Looking for a heater and air conditioning that
1. Doesnt use up alot room 2. It's more electric than heater is it possible |
Chevy addict
Re: Heat and air
Vintage AC is the way to go, don't know what you mean by electric.
C10 CLUB Y QUE!
Re: Heat and air
Re: Heat and air
A company called Old Air , and also Hot Rod Air at one time offered units that installed where the factory unit did. Actually worked pretty good.
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Heat and air
Vintage air sure fit is the best out there! Not cheap but....it’s the best option.
I have Old Air Products and it works fine, only issue I ever had was the blowe motor bearings went out after 10 years....replaced and works fine. I’ve had it in my truck working for...15 plus years, even works with my LSx swap too!!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Re: Heat and air
You can go to the search is has been talked about before.
Moderator
![]() ![]() Join Date: Aug 2011
Re: Heat and air
There is Old Air - http://www.oldairproducts.com/catalog/index.php
There is also Nostalgic Air - https://nostalgicac.com/ Many people use Vintage - http://67-72chevytrucks.com/vboard/s...d.php?t=467956 And Classic Air - https://classicautoair.com/shop/1966...ioning-system/
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 12-04-2017 at 09:27 AM. |
