Leaking Fuel Pump - Easy to replace?
The fuel pump on my 72 C20 is leaking, 5.7 V-8. Is this an easy thing to change or am I going to get in over my head? Will gas leak all over me when I change it? Any tips/tricks/comments?
Thanks, Emil 1972 Chevy C20 |
![]() Join Date: May 2007
Re: Leaking Fuel Pump - Easy to replace?
Easy to change. Lots of Vids on you tube. You will most likely get some fuel on your hands, but nothing major.
I bought the 3 line fuel pump for a 5.7 350 V-8, that's correct?
![]() Join Date: Jul 2015
For a 72? Or California truck? Mine is just a 2, in and out. Mine is a 70. Just crimp the fuel line coming out of the cab with a pair of vise grips. Should stop the flow. Make sure you get the gasket in, and the pushrod goes back in the way it came out.
Junior Member
![]() Join Date: Jul 2014
Sometimes the pushrod will try to fall out. Some guys use a dab of grease to hold it for the few seconds it takes to get the pump in place. If that doesn't work, most blocks have a tapped hole on the front you can run a bolt into that will hold the rod in place while you get the pump tightened in. Just don't forget to remove that bolt afterward.
Be sure and check the engine oil for over filled from fuel entering crankcase. Check to see how the oil smells.
'67 GMC 2500, 292, 4spd, AC |
Is your original fuel pump mechanical?
Mine was mechanical and it was a breeze. I removed it, cleaned the old gasket area with sandpaper, cleaned that residue off, and used a Carter replacement (mechanical) pump with new gasket. I tightened the bolts back in a little bit on each one to get the thing to seat all over instead of tightening down one bolt and then the other. I watched videos on the process but didn't need to glue the thing down at all. I think mechanical pumps are the way to go. |
Moderator
![]() Join Date: Jun 2008
Changing a fuel pump will raise your confidence level as a mechanic, that's for sure. Very easy to replace.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
Thanks for the info y'all, I'll be doing it Monday with the help of a mechanic friend.
I guess it's a California truck, I have 3 connection pump.
I guess California has been more complicated for a long time then.
![]() So you don't just have a mechanical pump on the side of our engine like my 250 does? *Mine is at 9 O'Clock in the pic, the brass-looking round thing. Last edited by In The Ten Ring; 12-03-2017 at 05:54 AM. |
I swapped it out Monday night, pretty cool experience! I now know what it feels like to have gas drain on you, haha!
#13 | |
Not sure, mine had 3 lines. One is fuel return, one from gas tank and one is that line that comes up into the engine, carb I think?
#14 | |||
"I ain't nobody, dork."
![]() Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#15 |
I went to all the trouble of reaching over my grill and down into the engine bay to change out mine only later to remove the entire front end.........
