Old 12-03-2017, 03:46 PM   #1
Ramiro0727
Electric fan thermostat temperature sensor switch
My son has a 69 C10 with a electric fan. He mounted the temperature sensor switch on the passenger side of the block. Today he noticed that the wire to the sensor switch is fried. Due to the wire hitting the headers. Is there another location he can move the sensor switch to? So he wont have this happen to him again. Can the sensor switch be moved to the housing for the thermostat?
Looking for suggestions.
Thanks,
Ramiro
Ramiro0727 is offline   Reply With Quote
Old 12-03-2017, 06:10 PM   #2
Steve Cole
Re: Electric fan thermostat temperature sensor switch
He can put the the sensor in the radiator if it has a boss for it.
Steve Cole is offline   Reply With Quote
Old 12-03-2017, 11:18 PM   #3
6T7 C10
If a V8 there is a hole/plug on the outer left side of each head and depending on the intake manifold there maybe a hole/plug on the crossover to the thermostat. Speaking of thermostats there are thermostat housings with a hole/plug built in as well.
6T7 C10 is offline   Reply With Quote
Old 12-04-2017, 02:08 AM   #4
57taskforce
All about them K’s
57taskforce's Avatar
I put mine in the intake. Works perfect.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
Old 12-04-2017, 10:39 AM   #5
Ramiro0727
Thank you all for chiming in. Look like we install it in the intake. Thanks again.
Ramiro
