![]() Join Date: May 2016
Help me plug this hole.
Can't find anybody that sells a grommet for this hole. It is located just below the gas pedal. Backing plate grommet is too small. Any help would be appreciated. Thanks.
![]() ![]() Join Date: Feb 2004
Re: Help me plug this hole.
Flexseal tape cut to fit.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 12-04-2017 at 06:56 AM. Reason: words |
![]() Join Date: Jun 2014
Looks like an emergency /parking brake cable grommet...
Randy |
It's a 67. Parking brake cable Is under the steering column. I have no idea what went there. It is under the Excelerator pedal. Too far over to be the emergency brake cable. RTV I guess.
![]() Join Date: Jun 2005
What size is the hole?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Ace hardware
Stan 67 swb BLU MULE posted via flip-fone |
![]() Join Date: Jan 2003
foil tape- inside and outside
1969 ![]() 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
The hole size is just a little bigger then the plug for the backing plate adjuster hole. Not a biggie. But it does seem to be a factory hole. I will plug it with something. Thank you for all the replies.
What are the dimensions of this hole?
Assuming it is big enough, you could fashion two steel plates to bolt into each other and tighten up, sandwiching the firewall between. Use pan-headed machine screws (actually one would do) and put the head of the machine screw on the inside (of the cab). You could use some sealer around the edge or even some foam gasket material from Lowe's to keep out moisture. |
one of these possibly fit or close enough to be trimmed?
square push in plugs https://www.mcmaster.com/#square-plugs/=1ajrscd ![]() square snap in plugs https://www.mcmaster.com/#rectangular-plugs/=1ajrsyd ![]() rectangular push in plugs https://www.mcmaster.com/#rectangular-plugs/=1ajrtab ![]() rectangular snap in plugs https://www.mcmaster.com/#rectangular-plugs/=1ajrtji ![]() or one of these maybe? https://www.heyco.com/Hole_Plugs/pro...ion=Hole_Plugs ![]()
I started out with nothing - and I still have most of it |
Thank you. I will definitely check into that. Thank you for the help.
