Old 12-05-2017, 07:47 PM   #1
beadblaster
beadblaster's Avatar
Windshield rubber
I installed the windshield into the rubber and then installed the trim with no problems. I was installing the rope around the gasket and noticed that the top of the windshield gasket is tight getting the 1/4” rope in while the bottom seal area is wide and you need tape to hold rope in place otherwise it just falls out. It also seems that that the rope is quite a bit deeper in the seal on the top than the bottom. Just wondering if this is normal. The seal is a lmc seal. Thanks
beadblaster is offline   Reply With Quote
Old 12-05-2017, 08:24 PM   #2
Andy4639
Old member
Andy4639's Avatar
Question Re: Windshield rubber
I don't remember mine being that much difference between top and bottom. I didn't use LMC gasket though.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
