Flat out engineering C-4 axle problem
The bracket that mounts the dog bones to the hub assembly cut into my aluminum axle. Went in about 1/2". Everything is tight and mounted properly. Only did it on the drivers side. Got a new axle and replaced all the bushings with polyurethane. There is only 1/4 inch between the bracket and the axle. Could the torque from my big block twist the axle mounts enough to do this or is there some other cause?
1957 Chevy 3100 402 BBC 700R4 transmission c-4 Flat Out Engineering suspension |
Post Whore
![]() ![]() Join Date: May 2015
Re: Flat out engineering C-4 axle problem
got any pics of your setup?...did you talk to Don at flatout?
I haven't talked to Don yet. Was just in the process of checking everything over again before I called to make sure I didn't miss something. Also it just got real cold in the shop as we got our first freeze last night. I'll give him a call and see what he thinks is going on.
