Old 12-07-2017, 05:58 AM   #1
La Zona Imagery
I found a source for brand new 6 lug OE rims that fit disc brakes (not trailer rims)
https://www.cooperrestorations.com/p...-bolt-pattern/
1965 Chevy C-10 350 V8
2003 GMC Sierra Crew Cab 6.0L 4x4
La Zona Imagery is offline   Reply With Quote
Old 12-07-2017, 07:31 AM   #2
PGSigns
PGSigns's Avatar
Re: I found a source for brand new 6 lug OE rims that fit disc brakes (not trailer ri
Have you tried em?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-07-2017, 11:12 AM   #3
jocko
jocko's Avatar
Oh no!!! The K5 wheels I’ve been hoarding have just plummeted in value!!! Ha. There’s a ton of chatter on the 67-72 side of the forum about these, to include the vendor. Reviews will be coming in soon. I think this is a great idea and long overdue, despite what it does to my 401K of steel wheels.
Old 12-07-2017, 08:05 PM   #4
La Zona Imagery
Originally Posted by PGSigns View Post
Have you tried em?
Jimmy
No. I just bought a set of smoothies from Summit racing a couple weeks back. Wish I knew about these OE wheels.
Old 12-07-2017, 09:01 PM   #5
VictoriaHardware
VictoriaHardware's Avatar
Don't get to worried-
The center hole is 2.75" and the originals are 3.5". They may work on front disc conversions, but will not fit on a rear axle.
The backspacing is 4.25" vs the Military wheels which are 3.875". For those with drop spindles the increased backspacing will not help at all with clearance to the LCA. The Military wheels require LCA trimming as it is.
They're 7" wide, not 8".
VictoriaHardware is offline   Reply With Quote
Old 12-08-2017, 12:18 AM   #6
Captainfab
60-66 Nut
I'm curious as to what the 'powder coated primer finish' is. Most powder coat is basically a plastic coating applied to metal. Automotive paint is not intended to be applied over plastic. In fact PPG will not warranty their products if applied over powder coat.
Old 12-08-2017, 08:04 AM   #7
PGSigns
PGSigns's Avatar
If the center hole is only 2.75 then the picture is not of the wheel they are selling. Also the 4 1/4" back spacing would be a no go on my 66. The 4" back spacing wheels on my 66 took a lot of trimming to get to work. Would not feel comfortable trying to make room for a 1/4" more. Now this is with 2 1/2" drop spindles so with stock height applications they would be OK.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 12-08-2017, 10:51 AM   #8
Cooper Restorations
Cooper Restorations's Avatar
I was just notified that the wheel specs on my website were incorrect. The center hole specs were wrong (they were specs for a smaller bolt pattern). And a couple had the backspacing listed wrong. Sorry for the confusion. All the specs have been corrected. Center hole for the 5 lug truck pattern is 3.125 and for the 6 lug pattern is 4.25" Backspace was also corrected to 4.125" for the 15x8's.
Cooper Restorations is offline   Reply With Quote
Old 12-08-2017, 11:00 AM   #9
Cooper Restorations
Here is a picture of the actual wheels. 15x10 on the left and a 15x8 on the right.
Old 12-08-2017, 12:19 PM   #10
PGSigns
PGSigns's Avatar
That is a nice looking wheel.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 12-08-2017, 12:27 PM   #11
Cooper Restorations
Thanks Jimmy. They are nice. And USA made.
