Old 12-07-2017, 10:40 AM   #1
AustinBelair
Wheel fitment with a 295 tire?
I'm used to the 60-66 world but I recently picked up an 87 short wide and want to buy some wheels for it. I have a new pair of 295/40/18 rear tires. I also have some 20" tires.
I'm looking at doing 18x9 front and 18x10 in the rear or 18x8 front and 18x9.5 rear. Does anyone know what backspacing I need to make this happen? Stock leaf springs with 2" shackles and will be dropped 1" in the front.
I looked for a wheel thread on here but didn't see one.
Thanks!
My mother is a recent cancer survivor and this truck build is for her
AustinBelair is offline   Reply With Quote
Old 12-08-2017, 10:27 AM   #2
AustinBelair
Re: Wheel fitment with a 295 tire?
Any help is appreciated
Old 12-08-2017, 10:47 AM   #3
ultrahd4me
ultrahd4me's Avatar
I might be able to help you. I have ran a 20x10 with a 285/50/20 with a 5.75 backspace with plenty of clearance. I had about 1" of clearance from the bulge of the tire to outer bedside. So I think with a 295 tire a 5.5 backspace would be perfect. This is the same setup I'm running on my current truck.
Follow me on Instagram: @midtennc10
Youtube channel: Midtennc10
ultrahd4me is offline   Reply With Quote
Old 12-08-2017, 05:03 PM   #4
Malo83
Cruzzzn' Vet
Malo83's Avatar
Nice!!
Malo83 is offline   Reply With Quote
Old 12-08-2017, 09:33 PM   #5
AustinBelair
Thanks Ultrahd4me! That helps. So in offset that equates to a 20x10 with a +6 so I could probably safely go -/+ around 6mm. Do you remember the details on the backspacing and tire size on the front?
Old 12-09-2017, 08:20 AM   #6
bluex
bluex's Avatar
You should have plenty of room for that size at such a mild drop. I'm running 295/45/20s on mine and still have room with it aired out up into the notch. 5" backspace on the front on a 8" wide and 5.5" on the rear for either 9.5 or 10 wide should work. That should be pretty much the standard size for most any wheel you could want.
bluex is offline   Reply With Quote
