Old 12-07-2017, 07:41 PM   #1
portworks
options for running vintage A/C and heater hoses with smooth firewall.
I know there's been quite a few threads about this before but I'm looking for a clean alternative to go possibly straight through the side of the cab above the fresh air vent and possibly into the passenger fender area. I would like it to be hidden as much as possible. Looking for experience from someone , with pics if possible. 1968 factory a/c cab.Smooth firewall.Newest vintage air kit.
portworks is offline   Reply With Quote
Old 12-07-2017, 09:42 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: options for running vintage A/C and heater hoses with smooth firewall.
Go behind the passenger inner fender down to the floor and back into the cab for a very clean look are as stated come through the side of the cab into the fresh air way.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-08-2017, 10:40 AM   #3
portworks
Does anyone have any pics of this or any other ideas to make the routing shorter and going all the way down and all the way back up then forward?
Old 12-08-2017, 01:41 PM   #4
dfwright
dfwright's Avatar
Many of the pictures in the old threads are gone, due to the photobucket fiasco. However, if you search the site for "Vintage Air Hoses", you'll find a number of threads where folks have run their hoses through the fender, or have a smoothed firewall with Vintage air.
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 01-26-2018, 05:16 PM   #5
portworks
Well this is what I ended up doing, and it wasn't too bad once you modify the piping for the hot water valve to the heater core. Then pulling the fender and inner Fender allowed good access to the cavity to drill and insert grommets. Other than that just normal A To B hose routing.
