10-31-2003, 04:06 PM | #1 |
Before and After
700 R4
Will a 700R4 from a 6.2 Diesel work well with a SBC with little or no modifications? I heard that it will shift too soon. It is supposed to have a 2500 stall?
Any comments?
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
10-31-2003, 04:12 PM | #2 |
Before and After
Oh ya.
Can these Trannys be shifted into 1st gear with a column shift?
10-31-2003, 04:54 PM | #3 |
2500 stall on a diesel? I thought diesels wanted the low end rpm. That is where they make there power. Or did someone add the torque converter later.
All in all, I think that trans is basically the same. |
10-31-2003, 07:53 PM | #4 |
Before and After
I'm not sure about the stall, The guy told me there was a 2500 stall in the diesels, but now that I think of it, you are right, they should have a lower stall than a gas one, if they are different.
11-01-2003, 12:52 AM | #5 |
its all about the +6 inches
It should be the same...if anything, it'd be a strong version. The 2500 stall deal is probably inacurate, but if you get one for a V-6 S-10 Blazer, I'm told it is something like 2500.
The tranny will shift pretty early onless you do some work to it. You figure the Deisel engine red lines at 3500 or so. |
11-01-2003, 01:32 AM | #6 |
huh ???
The 700R4 in my 72 was from a diesel. Right now I have a big block in front of it. You will have to change the TV cable to one from a gas motor. Also a buddy of mine that works for a trans shop said it should have around an 1800 stall stock...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
11-03-2003, 12:22 AM | #7 |
Before and After
Would it be smarter to buy one from a gas motor?, they will all be roughly the same price.
11-03-2003, 12:59 AM | #8 |
Sisyphus was my mentor!
I dont know about if it'll fit comming from a diesel BUT I have my 700r4 shifted by my factory column shifter & I couldnt figure out how to get it to go into first. With the OD you addan extra click so theres not enough travel in the stock shifter for first. Honestly, I never use it anyway & the gains far outweigh the losses. Enjoy your 700r4.
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
11-03-2003, 01:01 AM | #9 |
huh ???
My transmission buddy told me that the diesel version should me more stout than a gas version. I know the one in my dad's 84 truck first blew at 75000 miles, again at 80000 miles and was finally replaced at 85000 miles with a crate trans. The diesel version in my truck has over 200000 with never being worked on more than a regular service. I personally would go with the diesel version and replace the TV cable. Just me .02 though...
Chuck
11-04-2003, 07:31 PM | #10 |
Before and After
Is that all that I would have to do is replace the TV cable?
Sounds like a no-brainer, I thing I'll jump on the 700R4 bandwagon.
11-05-2003, 12:18 AM | #11 |
huh ???
That's all I have to do to mine. The diesel TV cable is just too short to use. everything else seams to match up fine...
Chuck
