Old 12-10-2017, 07:19 PM   #1
Jeffh
Removing 6 cylinder bellhousing
Any good ideas, tips or advice on removing the manual transmission bellhousing from a 6 cylinder that is stuck? Or is it even possible? I'm starting to think not...
Jeffh is offline   Reply With Quote
Old 12-10-2017, 09:04 PM   #2
jayoldschool
Moderator
Re: Removing 6 cylinder bellhousing
Is this is a 235 or a 230/250/292? Big difference.
jayoldschool is offline   Reply With Quote
Old 12-10-2017, 09:37 PM   #3
Jeffh
It's a 235
Old 12-10-2017, 11:59 PM   #4
Captainfab
60-66 Nut
Make sure you have all the bolts out and then wiggle and pry.
Old 12-11-2017, 04:59 AM   #5
Wrenchbender Ret
You can't get all the bolts out because some are in back of the flywheel. You can't get the flywheel out because you can't get to all the clutch bolts without turning the engine. If you are going to junk the engine I've seen where guys have pulled the oil pan & cut the crank in front of the rear main brg.
Wrenchbender Ret is offline   Reply With Quote
Old 12-11-2017, 02:09 PM   #6
jayoldschool
Moderator
I went through this on my buddy's 235. I removed the trans, removed the flywheel, and didn't bother taking the bellhousing off.
There are two bellhousing bolts that are under the flywheel, that's why you can't remove it, you still have two bolts in.
