Old 12-10-2017, 08:25 PM   #1
superhondaz50
superhondaz50's Avatar
Mismatched rear end, verify what I see please :)
Ok, so I literally read just about every thread on the different 12 bolt length and axle types, and I'm trying to figure out what is in my truck. My 12 bolt has a 69 date which is correct to my truck, 57" flange to flange, which is the shorter 12 bolt afaik, but it is a 5x5 lug pattern, and has the 71 style brake drums/system. What I believe I have is the longer axles in the shorter rear end, I notice that the brake pads are not even close to making full contact on the drums. Do you guys agree with my assumption that someone just threw in the longer axles to make it a 5 lug without regards to proper brake contact?
Thanks for the help.
Pad width:
Pad Wear:
Axle distance sticking out:
Drum/backing plate fitment:
drum Wear:
superhondaz50 is offline   Reply With Quote
Old 12-10-2017, 08:55 PM   #2
harpo231
harpo231's Avatar
Re: Couple differential and axle questions
Evidently lol sry
O O
0
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 12-16-2017, 07:57 PM   #3
superhondaz50
Pics posted for reference. Thanks
Old 12-18-2017, 09:58 AM   #4
superhondaz50
Anyone see an issue with just adding a spacer between the backing plate and differential to scoot the pads further into the drum?
Old 12-18-2017, 11:17 AM   #5
uncle
I know a guy that ran some for yes. Never had any problems. Guess it would depend also how much hp and your intended use for the truck. His were made from steel and obviously used grade 8 bolts.
uncle is offline   Reply With Quote
Old 12-18-2017, 11:37 AM   #6
superhondaz50
250HP, just gonna tow some jetskis.
Old 12-18-2017, 11:45 AM   #7
uncle
Should have said years instead of yes, but I can’t guarantee you won’t have problems. I can only say what he did.
Old 12-18-2017, 12:17 PM   #8
superhondaz50
Well I figure these 5 bolt axles have been on here 20-30yrs, just need full brake contact haha
Old 12-28-2017, 06:51 PM   #9
superhondaz50
Bumping this to see if anyone else here has ran the longer axles in the shorter housing.
Old 12-28-2017, 07:52 PM   #10
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Do yourself a favor and get the correct length conversion axles, or have stock 67-70 axles redrilled to accept a 5 lug wheel. Nobody will be running that combo on purpose that I am aware of.
A lot of cats have just slid the 71-72 longer axles in and called it good, not knowing that the brakes don't line up and the bearings aren't running on the axle in the right spot. So even using the non-existent "spacers" will do you no good.
I have a 1969 housing that I am using moser conversion axles with the 5 lug patten. They work great. Cost me about $260 bucks with free shipping from Summit Racing.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 12-28-2017, 08:22 PM   #11
superhondaz50
Can you link me to those mosers?
I've found
CPP
Yukons
Early Classic
And Ten Factory
But can't find 5 log mosers
Old 12-28-2017, 08:51 PM   #12
GASoline71
GASoline71's Avatar
Here ya go...
https://www.summitracing.com/parts/m...gmt5/overview/
Gary
Old 12-28-2017, 11:19 PM   #13
superhondaz50
Originally Posted by GASoline71 View Post
Sweet!!
Old 12-28-2017, 11:45 PM   #14
Robznob11
Robznob11's Avatar
I've found
CPP
Yukons
Early Classic
And Ten Factory
I ordered mine straight from moser. You can get options that way. I run a car 5 on 4 3/4 bolt pattern and screw in studs. You can also order them drilled in a dual pattern incase you wanted to change...
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 12-29-2017, 01:45 AM   #15
superhondaz50
Would be cool to have them drilled for 14x1.5 lugs.
