![]() Join Date: Mar 2013
Rear shock mount location question
Good afternoon all, I was down taking a look at the crossmember I installed this weekend and noticed something weird. The driver side shock mount holes are closer to the frame rail on the driver side than they are on the passenger side as shown below. Is this normal? I am converting from a leaf rear end so I have no prior experience with this crossmember.
Thanks! Nick |
Re: Rear shock mount location question
I can shoot you some pics when I get home this evening if no one replies by then. I know the pan hard bar connects in there somewhere too. maybe that's why its off. not 100% sure though without taking a look at mine.
Thanks. I'm just curious which set of holes is correct if they are not supposed to be offset to one side. I've got to remove the crossmember anyway to slot some holes, so poping in a couple of holes is no biggie.
![]() Join Date: Oct 2014
This is just an uneducated guess but maybe the factory moved the right shock over for tail pipe clearance ?
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
Mine is 2 1/4 On the one side and the other side is at 3 1/4
For shgrins, why not email GSI or another place that produces the top shock mount bars and ask if they offset as well before blasting holes in the parts.
Sometimes things are offset for vibration, or harmonics or whatever, but the exhaust clearance makes sense. But I could swear my factory tailpipe mount (still there) is on the driver side.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#9 | |
I made upper mount brackets and relocated my shocks when I built my traction link kit. All four shocks (front and rear) are now the same. I used the short front shocks.
what I have.
