Old 12-11-2017, 05:02 PM   #1
56weav
Rear sway bar
Good afternoon,
In an effort to improve the handling of my 86 GMC short bed I have read that a used rear sway bar from a suburban will accomplish some improvement.
Does anyone have experience with such and if so what year or years suburban am I looking to find the sway bar ?
Thank You
56weav is offline   Reply With Quote
Old 12-11-2017, 06:30 PM   #2
homemade87
Re: Rear sway bar
If you really want to improve the handling get the front oem sway bar . Made a big difference in my 82 . I feel no need for a rear .
I got mine at a local junk yard . The brackets on the frame are riveted . I had them off in about 20 min . Just start with a small drill bit and get bigger and hit them with a chisel . They popped right off .
homemade87 is offline   Reply With Quote
Old 12-13-2017, 07:10 AM   #3
MASONGMC
Re: Rear sway bar
hello
I run a Hellwig sway bar on my rear of my 1977 GMC stepside 4x4. And you didn't have to drill any holes to install either.
MASONGMC is offline   Reply With Quote
Old 12-13-2017, 09:30 AM   #4
56weav
Re: Rear sway bar
Thank you,
My truck has a front sway bar I’ll probably replace the front bushing with poly
Do you believe the rear bar was worth the effort and expense ?
I did find a c30 rear sway bar , it appears that it won’t mount up
Old 12-13-2017, 12:26 PM   #5
nonstop
Re: Rear sway bar
I just did this on my truck with a c30 rear bar. My truck is a K2500. Here is what I had to do:
I got the sway bar and u bolt mounts from the junkyard. I had to order square u bolts and CAST IRON u bolt plates ($20 each from eBay). The cast iron plates gave me a little bit more clearance around the shock mount. I still had to grind the passenger plate slightly. I also had to grind the drivers side sway bar mount plate in little bit.
I bolted up the swaybar similarly as it came off the donor truck. To make it fit, I had to Cut off the excess threads from two of the U bolts. I put in all new replacement bushings. As for the end links, I used all thread and tubing along with nylock nuts. I had to drill two holes in the frame, but that was the extent of any drilling.
In the end, it was a little more work than I expected, and I had to do things a little different since my truck has a 4 inch lift, but the rear sway bar was worth it in my opinion.
nonstop is offline   Reply With Quote
Old 12-13-2017, 01:05 PM   #6
PowerdbyChevy79
PowerdbyChevy79's Avatar
Re: Rear sway bar
how did it help with the handling?
1966 C10 "Mary"
1967 C10 Custom "Ole Blue"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 12-13-2017, 02:30 PM   #7
nonstop
Re: Rear sway bar
It feels flatter in turns and there is less body roll coming from the rear. On a side not (not sure if it’s related) my locker seems to have a little better manners on the street.
Old 12-14-2017, 08:47 PM   #8
56weav
Re: Rear sway bar
Thank You for you input everyone
