truck doesnt always start
About 1 out of every 10 times my truck wont start for what reason I dont know. When I try it again an hour or so later it starts no problem. Ive checked the alt, starter and all wires in between the only thing I havent checked is the ignition switch could that be the problem I dont want to buy one and it not be the problem was wondering if any body could help.
got good ground straps between the frame and engine???
a couple would be best ![]() |
forgot to add that I took them off of the frame sanded to bare metal and put them back still no luck
when you say it won't start....
it turns over..and won't start????? won't turn over???? |
when I turn the key its dead silent like theres no battery in it. Then a little while later it starts right up thats why I think it may be the ignition switch
My 69 did that. Had the battery tested and it turned out to be a little bit whacko.......gave odd readings. Replaced it and haven't had a problem since. That may not be your problem, but its a free place to start.......
2004 Silverado - Beater 1969 GMC - In progress http://67-72chevytrucks.com/vboard/s...d.php?t=441683 2011 Aveo - Work commuter 2013 Crestliner Fish Hawk 1650 - The reason no work gets done on the project truck. |
I would hazard a guess at a starter solenoid. Easy to figure out if you have a volt meter. When it does not start check the voltage at the little terminals on the starter. No volts = switch/wiring problem. Volts= solenoid problem
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
thanks for all the help guys I will try thoses things tomorrow and see what I come up with. Also if any more ideas please post.
Where's my beer?
I'll second the starter selenoid, my '71 had the same problem, but mine being stick I would just push it and it would start, I would always park downhill :p
I replace the selenoid one day and it hasn't done since then. |
Black 72 Chevy
Check the wires that are on the solenoid. On my truck they fried and that was causing a similiar problem.
72 Chevy, SWB, 350engine, TH400 |
Registered truck nut
Don't forget the battery cables. Check them with an OHM meter. They might look good on the end but be all corroded under the plastic covering.
MOUNT VERNON, WASH. STATE Need a part? Just PM me |
I had a 69 that did that very same thing. Do you have HEI? if so check to make sure that you have a switched hot wire to the bat.side of the HEI. hope this helps
#13 |
What are you running in the truck..........
Battery may not have enough reserve cranking power to do the job...... Check how old the battery is as well.....
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
#14 |
I don't know if you have headers. If you do the heat could cause the starter to do that. Mine starter like that and just got worse. I ended up changing it out with a smaller one from a late model Chevy.
