Old 12-13-2017, 05:06 PM   #1
Linz
Linz's Avatar
Shortened Driveshafts
Hi Guys
After a bit of searching I haven't really found an answer (if it's been covered I apologize) I have a 72 (longbox) and have recently done a 2/4 suspension drop. On my first drive since lowering it I managed to rip the welds from my hanger bearing hence the driveshaft dropping down. I managed to find a welder and tack it back up to make it home where it drove fine. I'm thinking this is just to much of a coincidence being it was fine before hand. So my question is do I need to shorten my driveshaft and if so how to go about it. It's a 2 piece so the front section or rear section or both?? I have an excellent driveshaft shop close perhaps they can advise. I was just curious if anyone else had run into the same problem. I bet I only need an inch or so shaved of. I'm thinking this is for sure the problem. Truck had factory heavy duty coils to start with so it was quite a drop.
Linz is offline   Reply With Quote
Old 12-13-2017, 05:17 PM   #2
harpo231
harpo231's Avatar
Re: Shortened Driveshafts
If shaft is out of phase , you'll need to get angles right above all
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 12-13-2017, 05:26 PM   #3
harpo231
harpo231's Avatar
https://www.youtube.com/watch?v=Idk3BVDVHq4
Good stuff on angles etc:
Stan
67 swb BLU MULE
Old 12-13-2017, 08:33 PM   #4
Linz
Linz's Avatar
Im sure the driveshaft phasing is fine I have no driveshaft vibrations etc. When the hanger bearing dropped down I noticed a bad cross in the rear universal so I thought I'd replace it while I had the driveshaft out. But had a hard time getting the driveshaft out because it was so tight. So that's why I'm thinking it needs some of.
Old 12-13-2017, 08:41 PM   #5
leddzepp
Moderator
leddzepp's Avatar
I have a 5/7 slam on one of my trucks. Pinion angle needed adjustment but driveshaft did not need to be shortened. I don’t think I know of anyone that has had to have a driveshaft shortened for a drop
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 12-13-2017, 08:44 PM   #6
tutone
tutone's Avatar
First off, you have a little wiggle room in the carrier brg mount. Unless for some unforseen reason that you don't, then slot the holes a dab. Your front shaft should have room to slide forward into the tail shaft another inch or so. There really is no need to shorten it . Do check your pinion angle to be on the safe side.
:My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=807535
1972 K10 swb/1968 Camaro 350/4spd
1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5
tutone is offline   Reply With Quote
Old 12-13-2017, 09:03 PM   #7
Linz
Linz's Avatar
Ok sounds good guys I'll look into that!! I just feel the whole driveshaft is a bit tight you shouldn't have to pry it out of the back yoke to get it out right. Maybe it was just that center bearings time to go.
Old 12-14-2017, 03:40 PM   #8
demian5
demian5's Avatar
What wedge do you recommend for a 4-5" drop?
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
