12-13-2017, 08:33 PM | #1 |
rearend that wil swap into 69 half ton
Been driving my 69 Panel quite a bit and noticing rearend is getting little louder. Figure not too long before it lets go.
Looking go another 12 bolt that will basically bolt in,Going to build it and just swap out. Wondering what year models will swap out,understand cpl years newer are little wider and thats not problem. Going to get posi unit and 3,73 gears for new piece.Wouldn't mind if 5 bolt axles either,better wheel options.
Only the stupid know too much to learn something new. |
12-13-2017, 10:19 PM | #2 |
1965 Chevy C10, 2005 4.8L/4l60
Re: rearend that wil swap into 69 half ton
63-70, early 70 will bolt in and are same width. 70 1/2 are 1.5” wider but will bolt in fine. 71-80 will work with new mounts(71/72 has coil also). 71-80 will be 5 lug also
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
12-14-2017, 09:09 AM | #3 |
Great info thanks. I have a few prospects that will work then.Just need to see if any have posi unit already. Never hurts if I can save few hundred bucks. Thats stupid thinking I'll just spend it plus dbl on next piece.LOL
12-14-2017, 02:14 PM | #4 |
I have both 5 and 6 lug 12 bolts I am going to post in the forsale section this weekend.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
