Old 12-14-2017, 03:34 PM   #1
Grumpy old man
Grumpy old man's Avatar
One for the small block decoders
I picked up this small block this morning ,it's a fresh rebuild and I bought it for less than the cost of the parts showing .New hei dist /wires/starter/water pump/fuel pump/ rams horn exhaust/ Edlebrock C3BX intake/ Nice valve covers and Holly double pumper . I paid $300.00 for it loaded in my truck .
VI208TBC
3970010
Grumpy old man is offline   Reply With Quote
Old 12-14-2017, 03:36 PM   #2
demian5
demian5's Avatar
Re: One for the small block decoders
http://www.mortec.com/castnum.htm has all your answers.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 12-14-2017, 04:35 PM   #3
rsavage
rsavage's Avatar
1970 350ci truck engine (TBC) V= made in Flint engine plant. Date is either I 208(208th day of September) or 12/08 8th day of December. Casting number was used for 1968 327 and 69-79 350 ci engines. It has an earlier style intake on it with the oil fill tube.
Nice score!
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 12-14-2017, 06:29 PM   #4
crazyjeenyus
crazyjeenyus's Avatar
Disclaimer: I can neither confirm nor deny the accuracy of the information below:
The resource I use (nastyz28.com) gives 3 options based on the "TBC" suffix code:
'70 350, C-10 to 3500, automatic transmission 255HP 4 Barrell Intake
'70 350, K-10 & 20, 3-spd manual transmission 255HP 4 Barrell Intake
'79 350, C-10 to 2500, manual transmission L LS9 165 HP 4 Barrell Intake
Info based on the 3970010 casting number gives 2 options:
'68 327 2-bolt main A body
'69-'79 350 185 to 370 HP 2/4 - bolt mains car, truck, vette
And I interpret the date stampings on the back of the block as follows:
9 - last digit of year block was cast
L10 - L is the month the block was cast, since L is the 12th letter in the alphabet this block was cast in December and 10 is the day of the month.
So, from here you kind of have to combine all the data and come up with something that satisfies all the different stampings.
I would I.D. this as:
'79 350 low compression truck engine with just under 200HP. Probably came with a SM465 - 4 speed manual transmission.
Since it has been rebuilt, it is very likely that the heads are not the original ones that came with the engine, which could greatly increase the HP value. All in all its probably a typical work duty truck engine.
'67 c10
'65 c10
crazyjeenyus is offline   Reply With Quote
Old 12-14-2017, 11:17 PM   #5
crazyjeenyus
On closer look, the 9 looks like it could be an 8 or a 3. That confuses things a little more.
The suffix code search only gives us two different years as a possibility:
'70 or '79
The casting number search however provides data that is more plausible:
'68 - 327
'69-'79 - 350
So, if we ignore the suffix code (TBC) the possibilities are:
If the number is an 8:
1968 327 block
1978 350 block
If the number is a 3:
1973 350 block
This frustrates things a little but I know from firsthand experience that it is possible to have a block that has conflicting information stamped/cast into it. The original 283 block that came with my '67 custom has a suffix code that only matches up with a 307. In C-10's 307's first came in 1968 and they had breathers in the valve covers. So when all else fails, open it up, measure the bore and stroke and do the math.
In your case large journal 327's and 350's are the same block so with the exception of the crankshaft (which could have easily been replaced) its not really possible to know for sure.
'67 c10
'65 c10
Old 12-14-2017, 11:51 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
'70 or '79
'68 - 327
'69-'79 - 350
1968 327 block
1978 350 block
1973 350 block
Yup. One of my younger sisters bought a '66 Malibu with a "4 Bolt Main 350" replacement engine. When I went to rebuild it, I found a small journal 327. Sellers can lie, or maybe just not really know what they have.
~Steven
Simi Valley, CA
Old 12-15-2017, 12:57 AM   #7
bruceman1968
bruceman1968's Avatar
Hey Grump, You got everything you need there to positively identify your block.
VI208TBC
3970010
L10
L10 is the casting date
L = December
1 = December 1st
0 = 1970
Your block was cast on December 1st 1970
3970010 in 1970(or 1971 see below) is a 350cid.
VI208TBC is V1208TBC
I's used for 1's is very common when found stamped on Blocks.
1208 = December 8th
Your Block was cast December 1st and assembled on December 8th in 1970.
Casting Date codes are the day, month and year they say they are, but Suffix codes go by Model Year. Your block is December of 1970 which is the 1971 Model Year. So when you look up TBC you have to do it for 1971.
In 1971 TBC = 350cid, 255hp, 350auto, LS9, 4bbl, 10,20 C or K
So you have a 1971MY 350 Truck motor.
Great price. BTW
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 12-15-2017, 01:40 PM   #8
toolboxchev
That would be nice if it were a 68 large journal 327!
Mighty Mouse!
toolboxchev is offline   Reply With Quote
Old 12-15-2017, 03:46 PM   #9
Grumpy old man
VI208TBC
3970010
L10
L = December
1 = December 1st
0 = 1970
1208 = December 8th
Great price. BTW
Thanks ,I guess I was just not firing on all my cylinders yesterday ! Everything is checking out on what he told me and I saw the pictures of what was left of his truck ,It got sideways and he lost it into a tree . Check out how long he ran it by the looks of the carb it wasn't very long . oil looks brand new nice green antifreeze drained all over in the bed of my truck on the way home all new bronze freeze plugs ,etc,etc , I'll stick it on a stand and pull the valve covers and give it a once over and if everything looks good I'll fire it up and see what I've got .
Old 12-15-2017, 07:26 PM   #10
bruceman1968
You really got a great deal on that. Nice score!
Old 12-15-2017, 10:06 PM   #11
Grumpy old man
Well I put it on a stand pulled the valve covers and plugs , spotless clean inside .drained the oil it has a Chrome oil pan ,cut open the oil filter and everything looked great so new filter new oil with some good ol STP That I've always used and turned it over by hand for a good while with some marvel mystery oil in the cylinders and watching the rocker action it has more than a stock cam in it , Adjusted the basic timing and with plugs out and a set of jumper cables turned it over for a few short spurts and it all sounds perfect ! I'll start it tomorrow and run it for a bit ,Then as long as it's OK tear it all apart and re gasket it . A squirt of new paint blast the intake manifold and exhaust manifolds and she'll be ready to drop in one of my 67 short bed frames. I got lucky with this one !
Now if I could just sell a few 250's I've got ...
Old 12-15-2017, 10:30 PM   #12
Grumpy old man
What do you think ?
Old 12-15-2017, 10:36 PM   #13
Orange67
Orange67's Avatar
Definitely a nice score!
Justin
'67 C20 CST Custom Camper
'04.5 LLY Duramax CCSB...sold
Orange67 is offline   Reply With Quote
Old 12-16-2017, 04:51 AM   #14
darkhorse970
darkhorse970's Avatar
Looks like a very good score to me. Congrats!
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 12-16-2017, 08:00 AM   #15
rsavage
rsavage's Avatar
I think you may have committed grand theft for $300!
1961 C1 Corvette
2021 Durango RT 5.7
Old 12-16-2017, 08:30 AM   #16
Grumpy old man
Old 12-16-2017, 08:42 AM   #17
CG
BlahBlahBlah
What size is that carb? I'm not even close to an expert on engine builds but it looks like a lot of carb for that engine. Guess it depends on the internals though. You did say the cam profile doesn't look to be stock. Are you gonna pop the heads?
Little block and accessory clean and paint. Get rid of the ugly (IMO) ball milled valve covers and put some vintage aluminum finned covers, and you are off to the races.
Old 12-16-2017, 09:07 AM   #18
Grumpy old man
Yeah that carb may be too much but I won't know until I start it today I'll pull it apart just to know for sure what they did to it , I'm already thinking of using the cowl intake plenum I have going to this spectre air intake carb plenum , I've been collecting all the pieces to use it on my tri power 292 but it might look cool mounted to this small block ? I did some digging and the Edlebrock C3-BX aluminum intake is old school 70's before the Performer intakes came along ,From what I've read they work really good and a lot of the C2 vette guys like them ?
http://www.jegs.com/i/Spectre/865/9849/10002/-1
Old 12-16-2017, 07:09 PM   #19
Grumpy old man
WOOOOO HOOOOOO !!! Runs perfect ! I've spent $$$$$$ on some small blocks that didn't run like this does .
Old 03-13-2018, 09:49 PM   #20
Grumpy old man
I pulled the pan and found a 4 bolt , new crank, new pistons,new cam that looks good ,rods appear to have been balanced ,Everything looks great !
My $300.00 special
Old 03-13-2018, 10:45 PM   #21
rsavage
rsavage's Avatar
Can't beat that deal!
1961 C1 Corvette
2021 Durango RT 5.7
Old 03-13-2018, 11:09 PM   #22
davischevy
davischevy's Avatar
A home run I would say.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 03-13-2018, 11:17 PM   #23
With that dbl pumper I'd expect some changes have been made internally, like came at least
