Old 12-16-2017, 11:48 AM   #1
Graham57a
Graham57a's Avatar
Spare Tire Carriers
So I have my eye on a factory style spare tire carrier that goes behind the rear seat. And the one I am looking at has a few minor differences from the tire carriers I’ve seen on this board. The owner claims they make two different types of spare tire carriers but I can’t seem to find any matching this type. What do you guys think? It looks right to me but I don’t see a slot for the hub bolt and the other examples I have seen have a pressed in raised area at the slot and this one is flat all the way down. I also see an extra hole on the base legs.
Graham57a is offline   Reply With Quote
Old 12-16-2017, 11:49 AM   #2
Graham57a
Graham57a's Avatar
Re: Spare Tire Carriers
Pics for comparison
Old 12-16-2017, 05:03 PM   #3
jaros44sr
jaros44sr's Avatar
what size tire are you using?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-16-2017, 05:22 PM   #4
Graham57a
Graham57a's Avatar
31x10.5x15
Old 12-16-2017, 07:11 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Not certain but I think that some GM vans used a spare tire mount very similar to first gen k5s. Did second gen k5s use a similar mount as well?
Old 12-16-2017, 07:14 PM   #6
jaros44sr
jaros44sr's Avatar
Originally Posted by Graham57a View Post
31x10.5x15
That might just fit, weren't H78x15 factory
SAFETY FIRST
AS usual, off topic
Jim
Old 12-16-2017, 07:45 PM   #7
Graham57a
Graham57a's Avatar
Square body’s use a round tubing mount over the right rear. At least the ones I’ve seen
Old 12-16-2017, 07:49 PM   #8
ls1nova71
ls1nova71's Avatar
Pretty sure the early square body ones, maybe the full removable top trucks used a similar mount, which may be what this is.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-16-2017, 08:01 PM   #9
ls1nova71
ls1nova71's Avatar
The truck I posted is a copy I believe of the Blazer in Jaws. This is a screen shot. I don't think they would put a tire in a truck in a movie just because.
Old 12-16-2017, 08:21 PM   #10
jaros44sr
jaros44sr's Avatar
I was thinking rear view blocked by a big tire
SAFETY FIRST
AS usual, off topic
Jim
Old 12-16-2017, 10:38 PM   #11
Hotrod1972GH
Active Member
Hello My dad work on the Assembly Line for GM in the 1970s and we talk about the spare tire holder he Alway said a blazer only had the two hole and a suburban 3 hold for the floors where made of wood and need more support , I hope this help
Hotrod1972GH is offline   Reply With Quote
Old 12-17-2017, 01:35 AM   #12
GM man
GM man's Avatar
Here's mine. The legs look similar but the slit in the middle of yours looks completely different. I've never seen one like that before.
1972 GMC Jimmy 6.0/4L65
1972 Chevrolet long bed 1/2 ton
GM man is offline   Reply With Quote
Old 12-18-2017, 10:05 PM   #13
CrewCab59
CrewCab59's Avatar
Yes the sportsman van's used the same style spare mount and the 73-75 full top k5.
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 03-19-2019, 01:02 PM   #14
CJM72
Bringing back an old thread to see if this was ever figured out. Looking at one identical to the one the OP was looking at. Can anyone confirm if this is from something other than a 69-72 Blazer? It doesn't look like you could adjust to a bigger or smaller tire with the fixed bolt location.
CJM72 is offline   Reply With Quote
Old 03-19-2019, 08:54 PM   #15
too much stuff
Roadtrip!
too much stuff's Avatar
The suburbans had a well on the pass side to hold a spare tire.
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again...
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 03-20-2019, 05:11 PM   #16
HeloCrewChief
HeloCrewChief's Avatar
I bought one like the top one from a forum member. My guess is it is out of a van or newer blazer. It works fine with my stock spare and the only difference I see is that the bolt does not have the slot adjustment.
1970 C10 to K20 conversion
1974 GMC Jimmy
1968 50th Anniversary Short Bed
1968 Chevelle
1964 Comet Caliente
1990 W250 Cummins
HeloCrewChief is offline   Reply With Quote
Old 03-20-2019, 07:31 PM   #17
rsavage
rsavage's Avatar
31x10.5x15
If I remember correctly from my 71 Blazer, you might have difficulty trying to fit a 31" tire with the inside rack in the original position.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 03-20-2019, 10:18 PM   #18
simicrintz
'71 here with 31's; it is a bit wonky.....
-Bruce
1971 K5 Blazer 4WD
simicrintz is offline   Reply With Quote
