12-17-2017, 10:22 AM | #1 |
Windshield Washer Reservoir
This is a new one.
I fill the washer reservoir and it's empty in no time. Must have a leak. I've never come across a leaking washer fluid reservoir. Anyone else dealt with this?
Present: 2015 Tacoma. Yeah, not a GM, but I love it. 1969 GMC 32,000 - fix, drive, relax, fix... 2019 BMW R1250 GSA - Yahoooooooo 1979 Honda GL 1000 - retro touring at its best. Past: '05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner. '94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm. '79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350. '76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod. '68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect. '59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said. |
12-17-2017, 11:21 AM | #2 |
Re: Windshield Washer Reservoir
The washer pump is located on the outside of the tank at the bottom and a likely culprit. I've had to change the pumps on my '04 and '05. The bodies cracked and let the fluid drain out.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
12-18-2017, 02:31 AM | #3 |
If it doesn't just run out on the ground when you fill it, it could be the hose from the pump has a hole in it by the battery.
12-18-2017, 03:39 AM | #4 |
^ yep, my '02 had a b/o hose..
one day filling it up, started peeing on the ground half way full.. figured the res was cracked, ordered replacement, and found hose when I pulled it.. thankfully, dealer took the new unmolested res back no worries
I started out with nothing - and I still have most of it |
12-18-2017, 09:10 AM | #5 |
Dont know if this was your problem or not , but gm had a problem with battery acid deteriorating the components . The battery sits right at it . I could fill mine and it would run out until it was half full and then stop . I had parted a 04 out and had an extra . Installed it in my 06 and no more leak .
12-18-2017, 09:23 AM | #6 |
Normally its the pump breaking pull back the driver side inner linner and take a look they are like 29 buxs if you need a tank dorman sells them
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
