Blazer tank conversion
There's been a lot going on with these conversions and I'm in the middle of finishing mine up but I have a question on running lines and what to which and where.
On my original 70 tank, there was the filler and the supply. No vent or return to a canister. (Not sure if all years of our trucks have canisters or I'm running around missing something) My new tank, 85 blazer with manual sending unit. I'm planning on hooking up the filler (obviously), I have the supply line run and will tie the vent into the filler neck but there are two other lines that I have capped right now. I know one is the charcoal and the other who knows. Any help on how I should run these let me know. I'll post pics of the install when complete. ![]()
Jimmie Modern Vintage Autoworks - '70 Chevy C10 - '74 Chevy C30 3+3 Dually - '04 Chevy Colorado Built, NOT, Bought. If you build it...they will ENVY! Drive Slow, Scrape Hard, or Take Your Truck and GO HOME! |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
One could be a return line would be my guess ... But not sure..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Post Whore
![]() Join Date: Feb 2001
One should be used as a vent. I have a one way valve on mine. The other can go to a charcoal cansiter or cap it.
Thanks for the help. I just cap them off, truck runs fine the way its plumbed (hopefully, I only test ran it for a short time)
I suppose since I didn't have any other lines from my in-cab tank I'll be good. Thanks again
